OT: Kerberos ticket renewal 10.7
  • March 20, 2012
  • 11 replies
  • 78 views
Forum|alt.badge.img+19
A bit off topic - but putting this out there anyway...
With 10.6.x the Kerberos Agent would pop up a polite GUI requesting password which could be called from a script as follows: echo '' | sudo -u $user kinit
This could be used to automate prompting a user to re-authenticate and preventing ticket expiry.
With Kerberos changes in Lion what are others using to prevent ticket expiry/renewal?
Thanks,
Lisa.
Best answer by rich.trouton
Peter Bukowinski just posted this on his Twitter feed:
https://gist.github.com/2149196
try
    -- test for Kerberos ticket presence and attempt to renew
    set kerb to do shell script "/usr/bin/klist | /usr/bin/grep krbtgt"
    set renewKerb to do shell script "/usr/bin/kinit -R"
on error
    -- offer to renew Kerberos ticket
    set response to (display dialog "No Kerberos ticket was found. Do you want to renew it?" with icon 2 buttons {"No", "Yes"} default button "Yes")
    if button returned of response is "Yes" then
        try
            set thePassword to text returned of (display dialog "Enter your password:" default answer "" with hidden answer)
            do shell script "/bin/echo '" & thePassword & "' | /usr/bin/kinit -l 10h -r 10h --password-file=STDIN"
            display dialog "Kerberos ticket acquired." with icon 1 buttons {"OK"} default button 1
        on error
            try
                set thePassword to text returned of (display dialog "Password incorrect. Please try again:" default answer "" with icon 2 with hidden answer)
                display dialog "Kerboros ticket acquired." with icon 1 buttons {"OK"} default button 1
            on error
                display dialog "Too many incorrect attempts. Stopping to avoid account lockout." with icon 2 buttons {"OK"} default button 1
            end try
        end try
    else -- if No is clicked
        quit
    end if
end try
  • March 21, 2012
set thePassword to text returned of (display dialog "Enter your password:" default answer "" with hidden answer) do shell script "/bin/echo '" & thePassword & "' | /usr/bin/kinit -l 10h -r 10h --password-file=STDIN"
that renews for 10 hours
will only work in cases where you don't need to re-enter your password. If you do need to enter the password again
Forum|alt.badge.img+33
  • March 21, 2012
try
on error
        try
        on error
            try
            on error
            end try
        end try
        quit
    end if
end try
  • March 21, 2012
Thank you - will make a few changes and do some testing
  • March 21, 2012
me and Peter talked about this this morning that was the solution we came up with.
if you make a launcher agent to run an apple script app to run this every 9.5 hour since tickets expire every 10 hours
<plist version="1.0">
<dict> <key>Label</key> <string>com.logon.RenewKerberos</string> <key>ProgramArguments</key> <array> <string>/Applications/~~ Misc/Renew Kerberos Ticket .app/Contents/Resources/Scripts/main.scpt</string> </array> <key>RunAtLoad</key> <true/> <key>StartInterval</key> <integer>34200</integer>
</dict>
</plist>
  • March 22, 2012
Thank you for sharing!
The script runs well, though I made a few site specific changes. Will run via policy rather than launchd so to distinguish for laptops whether on or off site.
  • March 27, 2012
am trying to push it out as a policy but am getting an error:
"AppleScript execution error: No user interaction allowed. (-1713)"
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • March 27, 2012
Policies will run under each machine's local Casper administrative account but the AppleScript must run under the user account that needs its Kerberos ticket renewed.
Running the script using the launchd agent you mentioned earlier is probably the better solution for triggering this.
  • March 28, 2012
The script is running in testing, I modified the script. My understanding was that policies run as root, so the kinit would need to run as the user.
sudo -u $username kinit
  • March 28, 2012
can you post your modified version of the script
  • March 29, 2012
Sorry I can't post the whole script. however here are the excerpts and explanation that I think are important. This is the snow leopard version. For Lion use the apple script above to generate the UI, however same logic to determine the user, and run as the user.
Determine the current user as the policy runs as root and you need tickets for the logged in user not root:
user=/usr/bin/who | /usr/bin/grep console | /usr/bin/cut -d " " -f 1
echo "identified user is $user"
Determine when the users ticket is set to expire and later use this time to attempt to renew if within a threshold you determine. (ie. if ticket expires within x, then attempt to renew)
sudo -u lets you run as the user rather than for root.
kexpire=sudo -u $user klist | grep krbtgt | awk '{print $3, $4}'
use the -r option with kinit to attempt to renew.
or request a ticket if the ticket has expired.
echo '' | sudo -u $user kinit -l 10h
In snow leopard this will cause the kerberos agent to launch and prompt for password. The Apple Script above provides the UI for the Lion users.
Scope by policy to Lion or snow leopard clients (2 scripts). Run on every hour with ongoing frequency depending on your ticket lifetimes - be sure to exit early if there is no logged in user.
  • May 20, 2014
This information is helpful. I am a novice when it comes to automating this process. We have an issue where if our users restart their computer their kerberos credentials are removed. We have many laptop users and they do not connect via Ethernet before logging back in after restarting. This means they do not acquire a new Kerberos ticket. We also use Centrify Express to bind our Macs. Is there a way to automate this process for our Mac laptop users?
I've created an AppleScript command that can be run via Self Service after they've logged in and are connected via Wi-Fi to retrieve a new Kerberos Ticket so that they can print.
#! /bin/sh
osascript -e 'launch application "Terminal"' -e 'tell application "Terminal" to activate' -e 'tell application "Terminal" to do script with command "login $USER" in window 1' -e 'delay 15' -e 'do shell script "killall Terminal"'
It would be great to just request the ticket for them automatically using the currently logged user's password. Is this possible? Thanks for the help!
