JSS 9.24, OS X 10.9.2
We install our config profiles via script (i.e., create and download from the JSS and use /usr/bin/profiles to install). When doing this, the restricted pref pane gets applied to root and, unlike our management admin account, root does not receive the prompt to enable/disable the restrictions at login as per our login window config profile.
Question one: anyone else seeing this? Any way to omit root from the restriction or at least get it the login window prompt we're seeing with regular admin accounts?
Additionally, if I remove all the config profiles, unenroll and removeFramework on a machine, the restrictions are still getting applied for root.
Question two: how is that happening? Where might root be getting its restriction from in this case?
Thank you very much for any insight.
