Show of your self service
  • November 5, 2013
  • 65 replies
  • 279 views
I been wondering what kind of things people offer on there self cerise. Show off screenshots and list what you offer.
  • November 5, 2013
external image link
  • November 5, 2013
Hey @jacob_salmela - see you've got caches in there. Do you have users rebooting afterwards and if so, are you using the built-in option for that?
  • November 5, 2013
I do not have a reboot attached to it.
The usage of those two jobs are pretty low, so I mostly have it there in case I am on a support call; I can have them run that and then reboot if necessary.
  • November 6, 2013
Hi Jacob,
Can you provide info on how you have "Install all updates" configured?
I'm looking at that option for our users for system and firmware updates.
Corbin
  • November 6, 2013
i would thing run the command
softwareupdate -i -a
  • November 6, 2013
Any one else what to show off there self service?
  • November 6, 2013
  • November 6, 2013
"i would thing run the command
softwareupdate -i -a"
I assume this will not work for a non-admin user to install.
stevewood
Forum|alt.badge.img+38
  • November 6, 2013
Actually, that's the beauty of Self Service. Since Casper runs as the root user, when you use a policy that runs "softwareupdate -ia" it is running as root. so it will work.
You can use Smart Groups and scripts to only have that option show up when there are updates to install on the machine, which is how we do it here.
  • November 6, 2013
Thanks, I'll give it a test with for our Mavericks deployment
  • November 6, 2013
There are quite a few scripts floating around here to gracefully (or not) close out of open apps - anyone have anything they particularly like? I've had mixed results and need to re-visit the subject as I gear up for Mavs..
  • November 6, 2013
@pete_c][/url][/url
Are you asking for something that kills all open running apps, or more for something that quits them gracefully, allowing users to save open work?
There are solutions for both, but they offer different experiences of course.
For the former, killing all visible running applications, you could try this-
RunningApps=$(/usr/bin/osascript << EOF
    set process_list to the name of every process whose visible is true and name is not "Finder"
end tell
EOF)
AppsList=$(echo "$RunningApps" | sed 's/, /_/g' | tr '_' '
echo "$AppsList" | while read app; do
    killall "$app"
done
For the latter, I think I may also have something I've used, but its slightly harder only because you need to use some Applescript (osascript) stuff, and at times, getting that to run properly with all the additional sandboxing in OS X makes it a little more difficult. Pure shell commands are often easier, but sometimes you can't avoid using Applescript.
  • November 6, 2013
external image link
bentoms
Forum|alt.badge.img+35
  • December 14, 2013
Late to the party but, we've just revamped it...
external image link
The scripts are either JSS policies at exist already, or are on my blog: [macmule.com](macmule.com)
  • December 16, 2013
@rlandgraf: very creative icon'ing. Hopefully you do not upset any Bruce's in your workplace!
  • December 16, 2013
@rlandgraf I exhaled sharply thorough my nose when I saw the icon for Send Log Files...
Forum|alt.badge.img+23
  • December 16, 2013
One good turn deserves another ...
external image link
I'm particularly proud of the rename computer icon ...
bentoms
  • December 16, 2013
@franton... lol nice.. are the plugins links that open in Safari? I tried to add a site that uses a java plugin & no-luck :(
  • December 16, 2013
They originally all opened in Safari ... now they just open in the Self Service window by request.
bentoms
  • December 16, 2013
@franton, so the Citrix one uses the Citrix Receiver plugin?
(Must retry..)
  • December 16, 2013
@bentoms][/url We just install Citrix Receiver 11. The address links to our citrix access website and it works from there. No special configuration needed. It's just an https address!
  • December 16, 2013
@bentoms You're actually not too far from me. One of my housemates works at Pentland. I'd be happy to discuss in person if you prefer?
bentoms
  • December 16, 2013
Sounds awesome.. pop in?
If your on Twitter... DM me @macmuleblog
  • December 16, 2013
This is great! I see there are many things I could be doing to improve Self Service for our users and Helpdesk!
  • December 16, 2013
Disclaimer: I work for an arts and design university.
I would suggest using png files at 256x256 resolution for your self service icons. Find or make these files with alpha channels enabled and a transparent background. They'll look more polished if done right.
My fav trick is doing a Cmd + I on an app bundle, select then copy the icon into preview, resize and save as a png. Looks great and no hunting on google image search!
