Hello all,
I am running 9.6.3 and Mac 10.10 Server. I have setup another distribution point mirroring the same settings of a known good distribution point and I am getting an error over HTTP/S download.
Error: Could not connect to the HTTP server to download Install Adobe Flash Player.pkg
I have unchecked the HTTP options and it works fine over AFP.
I have tested both HTTP and HTTPS on 80 and 443 respectively and always get that error.
I have taken out the link and re-added the link from /CasperShare/ to /Library/Server/Web/Data/Sites/Default/
I am also able to type in the file path in Safari and it will start the download. But whenever running from Casper Remote, I get that error.
Any ideas?
