Dockutil --remove fails
  • September 1, 2015
  • 18 views
Using version 2.0.2, seeing same results with 10.9.5 and 10.10.5, running CLI or through policy
administrator$ dockutil --remove '/Applications/Microsoft Office 2011/Microsoft Excel.app' --allhomes
item /Applications/Microsoft Office 2011/Microsoft Excel.app was not found in /Users/administrator/Library/Preferences/com.apple.dock.plist
also tried just using
It does exist in the plist and I tried different combinations of ' ' and to deal with spaces
<string>com.microsoft.Excel</string> <key>dock-extra</key> <false/> <key>file-data</key> <dict> <key>_CFURLAliasData</key> <data> AAAAAADUAAMAAQAA0QwbhgAASCsAAAAAAC0M +AA4/4oAANE4DXAAAAAACSD//gAAAAAAAAAA /////wABAAgALQz4AAAAGgAOACgAEwBNAGkA YwByAG8AcwBvAGYAdAAgAEUAeABjAGUAbAAu AGEAcABwAA8AGgAMAE0AYQBjAGkAbgB0AG8A cwBoACAASABEABIANkFwcGxpY2F0aW9ucy9N aWNyb3NvZnQgT2ZmaWNlIDIwMTEvTWljcm9z b2Z0IEV4Y2VsLmFwcAATAAEvAP//AAA= </data> <key>_CFURLString</key> <string>file:///Applications/Microsoft%20Office%202011/Microsoft%20Excel.app/</string> <key>_CFURLStringType</key> <integer>15</integer>
Best answer by mm2270
I don't think you need the full path when doing a remove. Try doing just
dockutil --remove "Microsoft Excel" --allhomes
The actual example in the help document actually shows this example:
dockutil --remove 'System Preferences' --allhomes
  • 7886 replies
  • September 1, 2015
  • 80 replies
  • September 1, 2015
Awesome, thats just too easy :) Thank you!
  • Employee
  • 19 replies
  • January 6, 2016
I'm seeing a strange issue with dockutil 2.0.2 . When we run the command using Casper dockutil won't work.
If we run the command locally on the mac it works fine. This is on 10.10.5
What we get is the dock refreshing but nothing happening.
the log is as follows
Preparing Policy...
Executing Policy 2016-01-06 at 2:38 PM | jssadmin | 1 Computer...
Running command dockutil --remove 'TextEdit' --allhomes...
Result of command:
item TextEdit was not found in /Users/dcs/Library/Preferences/com.apple.dock.plist
Thanks
