FUT/FEU when caching a package
  • November 15, 2016
  • 20 views
Hello all,
We are pushing a large package for the first time after our JAMF deployment. We want to cache/install cache to reduce user downtime during installation. We will use two separate policies: one to cache the package, the next to install cache via self service. Will I need to check FUT/FEU under both policies, or just the install cache policy? Does it make any difference?
Thank you
Best answer by Josh_Smith
It won't matter on the cache policy, it only matters on the install policy. It won't hurt to have it selected on both.
  • November 15, 2016
  • November 16, 2016
Thank you Josh.
