Java Runtime 7 update 60 issue with Extension Attribute
  • June 5, 2014
  • 37 views
Hey guys,
I was updating my image recently and I decided to move to Java Runtime 7. I noticed that after I started using this, the Extension Attribute stops working, or rather it reports as not installed even though it is.
This is the EA that I'm using:
#Check if java_home is defined
javaHome=`/usr/libexec/java_home 2> /dev/null`;
if [ ! -z $javaHome ]
then
vers=`java -version 2>&1 | grep "java version" | awk '{print substr($3,2,length($3)-2);}'`
echo "<result>$vers</result>"
echo "<result>Not Installed</result>"
I think I know what the problem is, I just don't know how to fix it.
It seems that when it tries to run "java -version" from terminal it fails because we don't install the JDK. (If I go to terminal and type "java -version" it attempts to give the site to install the JDK).
We would rather not install the JDK as well, unless necessary.
Anyone have any thoughts?
Sincerely,
TJ
Best answer by mm2270
I've seen this as well recently on a Mac that did not have the JDK installed. Only thing I can recommend is changing the Extension Attribute to pull the version string from the Info.plist for the Internet Plug-In
then
vers=`defaults read /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist CFBundleVersion`
Note that the above will return something like:
1.7.60.19
If you change CFBundleVerison to CFBundleShortVersionString, you get a more human readable:
Java 7 Update 60
Choice is yours on which to use. The former will be closer to what the java -version command was previously pulling, but not actually the same thing.
  • June 5, 2014
then
1.7.60.19
Java 7 Update 60
  • June 5, 2014
Brilliant!
Thank you so much! This was what I was going to try to do after brainstorming for a bit.
Much appreciated, sir.
Cheers!
