Error installing the computer level mdm profile
  • May 7, 2015
  • 19 views
I was using a quick add package and got "! The installation failed. The following installation step failed: run post flight script…"
I ran sudo jamf enroll -prompt and got this:
The JSS is available.
Enforcing login/logout hooks...
Error installing the computer level mdm profile: profiles install for file:'/Library/Application Support/JAMF/tmp/mdm.mobileconfig' and user:'(null)' returned -25300 (The operation couldn’t be completed. (OSStatus error -25300.))
Problem installing MDM profile.
Problem detecting MDM profile after installation.
Enforcing scheduled tasks...
Creating launch daemon...
Creating launch agent...
Checking for policies triggered by enrollmentComplete
It looks like there is a problem installing/detecting the computer level MDM profile. Any one ever experienced this issue?
bentoms
Forum|alt.badge.img+35
  • May 11, 2015
@dlee_pausd was this a QuickAdd created with recon or via the JSS enroll portal?
  • June 5, 2015
I am seeing the same error.
I'm using Casper 9.7
I imaged a computer using Casper Imaging
The workflow had a QuickAdd to enroll the Mac
It also occurs if I try to re-enroll the Mac with the terminal command sudo jamf enroll -prompt
  • June 6, 2015
It was just an expired SSL cert....
