Netboot across subnets with newer Macs
  • October 24, 2012
  • 34 replies
  • 121 views
I was glad to hear that I wasn’t the only person at JNUC who was having trouble netbooting over subnets with new Apple machines!
In order to netboot over subnets PREVOUS to Lion Internet Recovery being enabled on a mac, simply use the bless command (sudo bless --netboot --server bsdp://1.2.3.4)
For any computers that have Lion Internet Recovery Enabled (All 2012 macs and any 2011 mac with all EFI updates installed) the process is a little more conveluded.
Set up the netboot image like normal, but in the Server Admin app inside the Netboot pane, change the dropdown menu from NFS to HTTP. I am doing this off the top of my head so I’ll lead this post later when I can remember what the dropdown menu is called. Then, Take your NetBoot.dmg (found inside your .nbi folder) and place it on a web server somewhere that is visible to the client you would like the netboot from.
Below is an example of the command you need to use. My NetBoot server is 1.2.3.4, and my http server is 5.6.7.8. The http server can be the same as the netboot server, I just used different IP addresses in this example to show that you can place the actual NetBoot.dmg file somewhere on a web server (I placed mine in the root directory in this example)
Sudo bless --netboot --booter tftp://1.2.3.4/NetBoot/NetBootSP0/OS.nbi/i386/booter --kernelcache tftp://1.2.3.4/NetBoot/NetBootSP0/OS.nbi/i386/kernelcache --options 'rp=http://5.6.7.8/NetBoot.dmg'
I hope this helps everyone! I’ll update this a little later and try to make things a little clearer.
  • October 24, 2012
Jason,
Thank you for this post. That was me in the workshop who spoke up regarding the bless command, and the trouble we have had with trying to point to the NetBoot/SUS. It looks like I wasn't the only one either, and this document you posted is a HUGE help. Thank you for taking the time to post these steps. You saved me and my team a HUGE amount of time.
Have an awesome rest of JNUC!
Jason
  • October 25, 2012
I use this for 10.7 images.
Script taken from Internet
### Global Variables ###
server="xxx.xxx.xxx.xxx"
sharepoint="NetBootSP0"
### Fuctions ###
reimage () {
# Determine Arch value and point to proper netboot image
setName="Casper-NetBoot-10.7.2.nbi"
imageName="NetBoot.dmg"
protocol="nfs"
nextboot="--nextonly"
/usr/sbin/bless --netboot --booter "tftp://${server}/NetBoot/${sharepoint}/${setName}/i386/booter" --kernelcache "tftp://${server}/NetBoot/${sharepoint}/${setName}/i386/kernelcache" --options "rp=${protocol}:${server}:/private/tftpboot/NetBoot/${sharepoint}:${setName}/${imageName}" $nextboot
reboot
reimage
  • October 25, 2012
NetBoot is SLOW with the new MacBook Pro's we have been experiencing very slow netboots doing 20 machines in a lab we have to start 4 then wait for the netboot to get done and start 4 more. We had 600+ machines! It took a while but its done.
  • December 5, 2012
I was able to get this to work finally. Thank you. It helps a lot. I was going crazy trying to get Casper imaging up and running correctly. But now that I can netboot, I can't seem to get diskless working. Casper imaging crashes because it can't unmount the local hard drive. No matter what I do I can't get a Mac NetBooting with this method to use a network shadow file. Were you able to get this working?
  • December 6, 2012
I was able to get it working by creating a RAM drive with the rc.netboot file from this site.
http://www.macos.utah.edu/documentation/administration/setup_netboot_service_on_mac_os_x_10.6.x_client.x_client/setup_netboot_service_on_mac_os_x_10.6.x_client-diskless_netboot.html
Not sure why I was unable to use a network shadow drive, but the above did work for me.
  • January 19, 2013
Great tip!!!!!
If you are trying to boot a 10.8 netboot image, the URL is a little different.
Sudo bless --netboot --booter tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootXYZ.nbi/i386/booter --kernelcache tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootXYZ.nbi/i386/x86_64/kernelcache --options 'rp=http://5.6.7.8/NetBoot.dmg'
Just saved me from having to bring a laptop loaded with Server/NetBoot on it to re-image a couple of different areas that don't have access to our standard NetBoot service available! AWESOME!
donmontalvo
Forum|alt.badge.img+36
  • February 6, 2013
@taugust04 Thanks for the command, I confirmed it works on 2012 Late model Macs. Below is the command
sudo bless --netboot --booter tftp://XX.XX.XX.XX/NetBoot/NetBootSP0/MyNetBootImage.nbi/i386/booter --kernelcache tftp://XX.XX.XX.XX/NetBoot/NetBootSP0/MyNetBootImage.nbi/i386/x86_64/kernelcache --options 'rp=http://XX.XX.XX.XX/NetBoot.dmg'
Of course replace XX.XX.XX.XX with the IP Address for your NetBoot server, and replace MyNetBootImage.nbi with your NBI name.
Takes for friggin' ever to boot...LOL...but well worth it.
Thanks Ted!
Don
  • February 6, 2013
@taugust and others... if you are using the bless command to netboot across subnets, what kind of times are you looking at? (I know that there are other variables at play here; I am just looking for a rough ballpark of results).
  • February 7, 2013
I've been unofficially clocking boot times on the SAME subnet which is also relatively quiet (reserved mostly for imaging/testing) at about 5 - 6 minutes (100 mbit) to netboot to a 10.8.2 nbi. PATHETICALLY SLOW.... even on a 1000 mbit switch it's still 3 minutes. Oddly, my 10.6.7 nbi on the same 10.8 server boots in about 1 minute on 1000mbit, 2 on 100mbit.
I did clock it at about 11 minutes for a full netboot on a typically loaded switch out on the production floor. I've also noticed a graphical anomaly with 10.8 when I screen share into a mac, and reboot it to a 10.8 nbi. about 75% of the time it will reboot, and then I'll just get a gray window with an apple logo on it (you know, after about 12 minutes). I have to get the IP address of the Mac and then reconnect to it. Happens when the Mac's on the same subnet too, just faster :)
Annoying mostly, but is anyone else noticing this?
  • February 7, 2013
@donmontalvo so I should be setting up a webserver, and in the web servers directory I simply place the image file? Have you (or anyone else) had experience serving this from a mountain lion server?
donmontalvo
  • February 7, 2013
@acdesigntech Man, crow never tasted this good. :) So I jumped the gun when I posted. When I used this command last night, I got the big flashing globe followed by the little rotating globe followed by the circular progress icon...
external image link
...so when I saw the circular progress icon I went home. I came in this morning and the circular progress icon was still going. :(
When I hit the URL, the NetBoot.dmg file downloads fine. The only think I could think of is that it's owned by admin and was 644. So I changed it to owner is root and 755, and I stopped/started web services and NetBoot services. I left it in the same state tonight as I did yesterday, at the circular progress icon.
I guess I'll have my fingers crossed when I get in tomorrow. :)
[edit] Server is running 10.8.2 with latest updates
Don
  • February 9, 2013
@donmontalvo: Any update on this?
Besides the advantage of being able to host the netboot.dmg on a different server using http rather than nfs, any other advantages? Speed?
I was thinking rather than hosting another service on the server sI control, or (shudder) allowing servers i DON'T control to host the .dmg, just continuing to use nfs as the protocol for netboot. Thoughts?
donmontalvo
  • February 9, 2013
I got tired of futzing with NBAS so I took a couple of spare USB drives and dropped our RESTORE image on 'em...instant portable Casper Imaging drives. :)
  • May 14, 2013
Bump!
Still a bit new to this. 10.8.3 NetBoot image on a late 2012 Mac Mini. Tried using the following scripts with no luck.
Sudo bless --netboot --booter tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootML01.nbi/i386/booter --kernelcache tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootML01.nbi/i386/x86_64/kernelcache --options 'rp=http://5.6.7.8/NetBoot.dmg'
bless --netboot --booter tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootML01.nbi/i386/booter --kernelcache tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootML01.nbi/i386/x86_64/kernelcache --options 'rp=http://1.2.3.4/NetBoot/NetBootSP0/NetBootML01.nbi/NetBoot.dmg' --nextonly
/NetBootML01.nbi/ is where my NetBoot image lives.
Tested each one scoped to a policy that triggered at startup, once per computer. The policy executed but the computer never actually NetBooted with either version of the script. In the policy I chose to Override the Default Policy Setting for NetBoot Server and chose our internal server. Attached the script, and set it to run with the Before priority.
Also worth noting I guess that I've tried with both HTTP and NFS without success.
Is there a more efficient way to go about doing this? I've tried different sources outside of JAMFNation and had similar results. At this point one server per subnet isn't starting to sound like too ridiculous of an option if I just keep spinning my wheels trying to NetBoot across subnets :/
Appreciate any advice, thanks!
bentoms
Forum|alt.badge.img+35
  • May 14, 2013
If you attempt to NetBoot (holding N).. Then go into verbose mode (cmd + V)..
You should hopefully see some messages, please post them here.
  • May 14, 2013
@ dolivieri
In our environment I had to enable PortFast and set IP Helper address on our Switches.
Forum|alt.badge.img+20
  • May 15, 2013
@ dolivieri
Agreed netbooting across subnets with firmware updated macs is a huge pain and if you look around no one has been able to get this to work with out an ip helper.
The question is how is your netboot failing ? Does the machine just reboot or not even try?
Another problem is that the process has so many fail points. Does the machine get the booter file, is it able to download the kernelcache file over tftp before the machine automatically reboots.. the list goes on.
Also are you using 10.8 server?
The 2nd one you posted looks like it would work.
For NFS you need to change it a bit.
bless --netboot --booter tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootML01.nbi/i386/booter --kernelcache tftp://1.2.3.4/NetBoot/NetBootSP0/NetBootML01.nbi/i386/x86_64/kernelcache --options 'rp=nfs:1.2.3.4:/private/tftpboot/NetBoot/NetBootSP0:NetBootML01.nbi/NetBoot.dmg' --nextonly
  • May 15, 2013
so I have a situation with MacBookPro8,2 and 9,1 model types specifically: how do I get them to use the long (or short, i don''t care which) form bless command to netboot across subnets? This is my situation:
I have a netINSTALL that was created from (at the time) the latest and greatest 10.8 InstallESD.dmg. There is no mach.macosx file to speak of, so i cannot specify --kernel=......../mach.macosx, and since they run 10.6, they don't understand the --kernelcache switch.
For some reason they do not understand the shortform of the bless command (bless --netboot --server bsdp://....). They just end up rebooting to the internal hard disk. If i put them on the same subnet as the netboot server, the short form works just fine.
I did try copying a mach.macosx and associated mkext to my 10.8 netinstall so I could use the long form command, and the computer takes the command and reboots, but just sits at the gray apple screen and never boots any further than that.
I'm at a loss as to how to go about this. I have not run across any other model types that have this issue.
  • May 15, 2013
I'll cover all four ways to do this (and I really hope I didn't make a typo). I've played with NetBoot/NetInstall across subnets using the long form quite a bit. For NetBoot, not NetInstall, you need to specify the kernel/kernelcache option. You can omit both when doing an NetInstall. I always use the "--verbose" and "--nextonly" flags. They are not necessary.
Variables:
ipAddress='xxx.xxx.xxx.xxx'
nbiName='NetBoot.nbi'
dmgName='NetBoot.dmg'
NetBoot for a server running OS X Server:
bless --verbose --netboot --booter "tftp://${ipAddress}/NetBoot/NetBootSP0/${nbiName}/i386/booter" --kernelcache "tftp://${ipAddress}/NetBoot/NetBootSP0/${nbiName}/i386/x86_64/kernelcache" --options "rp=nfs:${ipAddress}:/private/tftpboot/NetBoot/NetBootSP0:${nbiName}/${dmgName}" --nextonly
NetInstall for a server running OS X Server:
bless --verbose --netboot --booter "tftp://${ipAddress}/NetBoot/NetBootSP0/${nbiName}/i386/booter" --options "rp=nfs:${ipAddress}:/private/tftpboot/NetBoot/NetBootSP0:${nbiName}/${dmgName}" --nextonly
NetBoot for a server running JAMFs NetSUS/NetBoot appliance:
bless --verbose --netboot --booter "tftp://${ipAddress}/${nbiName}/i386/booter" --kernelcache "tftp://${ipAddress}/${nbiName}/i386/x86_64/kernelcache" --options "rp=nfs:${ipAddress}:/srv/NetBoot/NetBootSP0:${nbiName}/${dmgName}" --nextonly
NetInstall for a server running JAMFs NetSUS/NetBoot appliance:
bless --verbose --netboot --booter "tftp://${ipAddress}/${nbiName}/i386/booter" --options "rp=nfs:${ipAddress}:/srv/NetBoot/NetBootSP0:${nbiName}/${dmgName}" --nextonly
Good Luck!
  • May 16, 2013
@josh_s: thanks for the info. unfortunately I'm getting the same results. I'm VPN'ed into the office right now so Can't get too many log entries from a verbose boot.
I may just end up recommending that we pick up the units and image them on the same subnet as the NB server... We've already wasted many precious hours trying to use NBAS.
  • May 16, 2013
@acdesigntech
First reset the pram on that machine then try this.
bless --netboot --booter tftp://ipaddreessofserver/NetBoot/NetBootSP0/Netbootname.nbi/i386/booter --options 'rp=nfs:ipaddressofserver:/private/tftpboot/NetBoot/NetBootSP0:Netbootname.nbi/dmgname.dmg' --nextonly
Troubleshooting wise you can find out what the problem is by using verbose mode. After you fire off that command hold down command+V that will let you see what is happening behind the grey screen. This will tell you the problem.
You can make sure that the netboot share is available by running this on the macbook.
run this command
showmount -e ipaddressofserver
then you can check to make sure the booter file can download
run this command
tftp ipaddressofserver
then you will see a prompt
then run this
get NetBoot/NetBootSP0/netbootname.nbi/i386/booter
this will let you know if the macbook can receive the booter file or not
  • May 16, 2013
If you're still having issues, I suspect it's an issue with your image. Can you NetBoot to it while on the same subnet? Also, the "booter" and Mach/kernelcache files are *not* interchangeable between images. Don't copy these files between nbi folders.
The only thing I've really been able to do to the modification that didn't break my nbi is to modify specific files on the NetBoot image and change the format of the NetBoot image itself (I usually use sparseimage to speed transfer to different sites). I wouldn't do either of these until you can successfully boot across subnets without any modifications so you know if you "broke" your image with modifications.
Troubleshooting, at this point, really comes down to using tftp and nfs to connect to the server and make sure the files are available when you are not attempting to NetBoot. Verify your permissions on those files. They should be readable by everyone.
  • May 16, 2013
I wish it was the nbi. When the laptops on the same subnet it netboots fine. Imacs from 9,1 to 11,3 and MBPs 5,3 and 6,2 have no issues with NBAS To any of my nbis. I'll test the commands above to see what's going on.
  • October 30, 2013
Hi, has anyone done this with Mavericks machines?
Cheers.
  • October 30, 2013
@ ClassicII - it ended up being the PRAM. Resetting it worked.
