Just starting with NetBoot and curious about what average times are. When I start NetBoot it takes about 25 minutes over 100Mb ethernet to get to Casper Imaging. My NetBoot.dmg file is 9GB (unsure if that is normal). Does this seem right? That seems like a long time to boot up.
Also, when I'm looking at server i never see any connections under NetInstall. Just says "No clients connected". Shouldn't there be something listed the moment a system starts to boot? I get BSDP Inform, BSDP ACK[list], and BSDP ACK [select] shown in the logs.
Thanks
Which OS is the NetBoot hosted on?
Also, option boot the Mac. Select the NetBoot volume & immediately hold the CMD+V keys.
It should then verbose boot, & you can have some more feedback as to what it happening.
It's 10.9.2 with all updates applied. I did the option boot and have a fairly large log file. Only the first part will post. I'm not sure specifically what to look for in here.
4/15/14 12:59:42.000 PM bootlog[0]  BOOT_TIME 1397581182 0
4/15/14 1:02:39.000 PM syslogd[46] Configuration Notice:
ASL Module "com.apple.appstore" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" claims selected messages.
ASL Module "com.apple.bookstore" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.securityd" claims selected messages.
4/15/14 1:02:39.000 PM kernel[0] Longterm timer threshold: 1000 ms
4/15/14 1:02:39.000 PM kernel[0] PMAP: PCID enabled
4/15/14 1:02:39.000 PM kernel[0] PMAP: Supervisor Mode Execute Protection enabled
4/15/14 1:02:39.000 PM kernel[0] Darwin Kernel Version 13.1.0: Thu Jan 16 19:40:37 PST 2014; root:xnu-2422.90.20~2/RELEASE_X86_64
4/15/14 12:59:58.984 PM com.apple.launchd[1] *** launchd[1] has started up. ***
4/15/14 1:02:39.000 PM kernel[0] vm_page_bootstrap: 4034530 free pages and 127006 wired pages
4/15/14 1:02:39.000 PM kernel[0] kext submap [0xffffff7f807a6000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff80007a6000]
4/15/14 1:02:39.000 PM kernel[0] zone leak detection enabled
4/15/14 12:59:58.988 PM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
4/15/14 1:02:39.000 PM kernel[0] "vm_compressor_mode" is 4
4/15/14 1:02:39.000 PM kernel[0] standard timeslicing quantum is 10000 us
4/15/14 1:02:39.000 PM kernel[0] standard background quantum is 2500 us
4/15/14 12:59:58.992 PM com.apple.launchd[1] *** Shutdown logging is enabled. ***
4/15/14 1:02:39.000 PM kernel[0] mig_table_max_displ = 74
4/15/14 1:02:39.000 PM kernel[0] TSC Deadline Timer supported and enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=4 LocalApicId=6 Enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=5 LocalApicId=1 Enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=6 LocalApicId=3 Enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=7 LocalApicId=5 Enabled
4/15/14 1:02:39.000 PM kernel[0] AppleACPICPU: ProcessorId=8 LocalApicId=7 Enabled
4/15/14 1:02:39.000 PM kernel[0] calling mpo_policy_init for TMSafetyNet
4/15/14 1:02:39.000 PM kernel[0] Security policy loaded: Safety net for Time Machine (TMSafetyNet)
4/15/14 1:02:39.000 PM kernel[0] calling mpo_policy_init for Sandbox
4/15/14 1:02:39.000 PM kernel[0] Security policy loaded: Seatbelt sandbox policy (Sandbox)
4/15/14 1:02:39.000 PM kernel[0] calling mpo_policy_init for Quarantine
4/15/14 1:02:39.000 PM kernel[0] Security policy loaded: Quarantine policy (Quarantine)
4/15/14 1:02:39.000 PM kernel[0] Copyright (c) 1982, 1986, 1989, 1991, 1993
4/15/14 1:02:39.000 PM kernel[0] The Regents of the University of California. All rights reserved.
4/15/14 1:02:39.000 PM kernel[0] MAC Framework successfully initialized
4/15/14 1:02:39.000 PM kernel[0] using 16384 buffer headers and 10240 cluster IO buffer headers
4/15/14 1:02:39.000 PM kernel[0] AppleKeyStore starting (BUILT: Jan 16 2014 20:19:00)
4/15/14 1:02:39.000 PM kernel[0] IOAPIC: Version 0x20 Vectors 64:87
4/15/14 1:02:17.141 PM hidd[70] void __IOHIDPlugInLoadBundles(): Loaded 0 HID plugins
4/15/14 1:02:39.000 PM kernel[0] ACPI: sleep states S3 S4 S5
4/15/14 1:02:39.000 PM kernel[0] pci (build 20:00:24 Jan 16 2014), flags 0x63008, pfm64 (39 cpu) 0x7f80000000, 0x80000000
4/15/14 1:02:39.000 PM kernel[0] [ PCI configuration begin ]
4/15/14 1:02:39.000 PM kernel[0] console relocated to 0x7f80020000
4/15/14 1:02:39.000 PM kernel[0] [ PCI configuration end, bridges 15, devices 15 ]
4/15/14 1:02:39.000 PM kernel[0] AppleThunderboltNHIType2::setupPowerSavings - GPE based runtime power management
4/15/14 1:02:39.000 PM kernel[0] SATA WARNING: IDENTIFY DEVICE checksum not implemented.
4/15/14 1:02:39.000 PM kernel[0] mcache: 8 CPU(s), 64 bytes CPU cache line size
4/15/14 1:02:39.000 PM kernel[0] mbinit: done [128 MB total pool size, (85/42) split]
4/15/14 1:02:39.000 PM kernel[0] Pthread support ABORTS when sync kernel primitives misused
4/15/14 1:02:39.000 PM kernel[0] Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IONetworkInterface</string><key>IOParentMatch</key><dict ID="2"><key>IOPropertyMatch</key><dict ID="3"><key>IOMACAddress</key><data ID="4">aFs1jcIl</data></dict></dict></dict>
4/15/14 1:02:17.141 PM hidd[70] Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
4/15/14 1:02:39.000 PM kernel[0] com.apple.AppleFSCompressionTypeZlib kmod start
4/15/14 1:02:39.000 PM kernel[0] com.apple.AppleFSCompressionTypeDataless kmod start
4/15/14 1:02:39.000 PM kernel[0] com.apple.AppleFSCompressionTypeZlib load succeeded
4/15/14 1:02:39.000 PM kernel[0] com.apple.AppleFSCompressionTypeDataless load succeeded
4/15/14 1:02:39.000 PM kernel[0] srom rev:11
4/15/14 1:02:39.000 PM kernel[0] ARPT: 1.117164: BTCOEXIST off
4/15/14 1:02:39.000 PM kernel[0] ARPT: 1.118071: BRCM tunables:
4/15/14 1:02:39.000 PM kernel[0] ARPT: 1.118754: pullmode[1] txringsize[ 256] txsendqsize[1024] reapmin[ 32] reapcount[ 128]
4/15/14 1:02:39.000 PM kernel[0] ARPT: 1.121410: wl0: Broadcom BCM43a0, vendorID[0x14e4] BAR0[0xc1a00004]
4/15/14 1:02:39.000 PM kernel[0] 6.30.223.154 (r420397)
4/15/14 1:02:39.000 PM kernel[0] USBMSC Identifier (non-unique): 000000000820 0x5ac 0x8406 0x820, 3
4/15/14 1:02:29.866 PM fseventsd[71] event logs in /.fseventsd out of sync with volume. destroying old logs. (2855 154 1725733)
4/15/14 1:02:39.000 PM kernel[0] AppleUSBMultitouchDriver::checkStatus - received Status Packet, Payload 2: device was reinitialized
4/15/14 1:02:39.000 PM kernel[0] Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/PEG1@1,1/IOPP/UPSB@0/IOPP/DSB1@3/IOPP/UPS0@0/IOPP/pci-bridge@0/IOPP/ethernet@0/BCM5701Enet/en0
4/15/14 1:02:39.000 PM kernel[0] BSD root: en0
4/15/14 1:02:39.000 PM kernel[0] netboot: using network interface 'en0'
4/15/14 1:02:39.000 PM kernel[0] netboot: retrieving IP information from DHCP response
4/15/14 1:02:39.000 PM kernel[0] netboot: IP address 10.20.67.123 netmask 255.255.255.0 router 10.20.67.1
4/15/14 1:02:39.000 PM kernel[0] netboot: adding default route 10.20.67.1
4/15/14 1:02:39.000 PM kernel[0] netboot: retrieving root path from BSDP response
4/15/14 1:02:39.000 PM kernel[0] netboot: NFS Server 10.20.153.103 Mount /Volumes/Macintosh HD2/Library/NetBoot/NetBootSP0 Image /CasperNetBoot_1092.nbi/NetBoot.dmg
4/15/14 1:02:39.000 PM kernel[0] Ethernet [AppleBCM5701Ethernet]: Link up on en0, 100-Megabit, Half-duplex, No flow-control, Debug [796d,0301,0de1,0300,0081,0000]
4/15/14 1:02:30.335 PM com.apple.SecurityServer[40] Session 100000 created
4/15/14 1:02:34.016 PM distnoted[89] # distnote server daemon absolute time: 86.705399780 civil time: Tue Apr 15 13:01:07 2014 pid: 89 uid: 0 root: yes
4/15/14 1:02:39.000 PM kernel[0] root on 10.20.153.103:/Volumes/Macintosh HD2/Library/NetBoot/NetBootSP0
4/15/14 1:02:39.000 PM kernel[0] netboot_setup: calling imageboot_mount_image
4/15/14 1:02:39.000 PM kernel[0] IOHDIXController: NOTE: administrator is creating non-ejectable disk image
4/15/14 1:02:39.000 PM kernel[0] KDIFileBackingStore::_handleStart: initial R/W vn_open returned 30
4/15/14 1:02:34.783 PM fseventsd[71] log dir: /.fseventsd getting new uuid: 99540040-94F3-457D-B37C-6A278233DA34
4/15/14 1:02:39.000 PM kernel[0] imageboot_mount_image: root device 0x1000005
4/15/14 1:02:39.000 PM kernel[0] hfs: mounted Restore on device root_device
4/15/14 1:02:39.000 PM kernel[0] XCPM: registered
4/15/14 1:02:39.000 PM kernel[0] AppleSRP started.
4/15/14 1:02:39.000 PM kernel[0] hfs: set VeryLowDisk: vol:Restore, freeblks:92836, dangerlimit:111500
4/15/14 1:02:39.000 PM kernel[0] VM Swap Subsystem is ON
4/15/14 1:02:40.585 PM distnoted[89] assertion failed: 13C64: liblaunch.dylib + 25164 [38D1AB2C-A476-385F-8EA8-7AB604CA1F89]: 0x25
4/15/14 1:04:20.436 PM xpcd[91] Info.plist does not contain an XPCService dictionary: /System/Library/Frameworks/Security.framework/XPCServices/SecurityAgent.xpc
4/15/14 1:04:23.000 PM kernel[0] Waiting for DSMOS...
4/15/14 1:04:29.976 PM com.apple.launchd[1] (com.apple.softwareupdatecheck.initial[49]) Exited with code: 2
4/15/14 1:04:29.976 PM xpcd[91] Info.plist does not contain an XPCService dictionary: /System/Library/Frameworks/Security.framework/XPCServices/SecurityAgent.xpc
4/15/14 1:04:30.065 PM NetBootClientHelper[60] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:04:30.296 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[60]) Exited with code: 1
4/15/14 1:04:30.318 PM NetBootClientHelper[100] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:04:30.318 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[100]) Exited with code: 1
4/15/14 1:04:30.318 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 10 seconds
4/15/14 1:04:37.754 PM wdhelper[42] sandbox cache error 3850
4/15/14 1:04:47.752 PM stackshot[48] Timed out waiting for IOKit to finish matching.
4/15/14 1:04:57.401 PM NetBootClientHelper[102] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:04:57.402 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[102]) Exited with code: 1
4/15/14 1:05:04.858 PM NetBootClientHelper[103] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:05:04.859 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[103]) Exited with code: 1
4/15/14 1:05:04.859 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 3 seconds
4/15/14 1:05:11.396 PM NetBootClientHelper[104] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:05:11.396 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[104]) Exited with code: 1
4/15/14 1:05:11.396 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 7 seconds
4/15/14 1:05:16.000 PM kernel[0] flow_divert_kctl_disconnect (0): disconnecting group 1
4/15/14 1:05:16.683 PM xpcd[91] Info.plist does not contain an XPCService dictionary: /System/Library/Frameworks/Security.framework/XPCServices/SecurityAgent.xpc
4/15/14 1:05:16.818 PM appleeventsd[79] sandbox cache error 14: unable to open database file
4/15/14 1:05:22.691 PM NetBootClientHelper[113] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:05:22.691 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[113]) Exited with code: 1
4/15/14 1:05:22.691 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 6 seconds
4/15/14 1:05:24.197 PM configd[81] InterfaceNamer: timed out waiting for IOKit to quiesce
4/15/14 1:05:24.197 PM configd[81] Busy services :
4/15/14 1:05:24.197 PM configd[81] MacBookPro11,3 [1, 342849 ms]
4/15/14 1:05:25.009 PM NetBootClientStatus[59] dnssd_clientstub set_waitlimit:_daemon timed out (60 secs) without any response: Socket 4
4/15/14 1:05:28.000 PM kernel[0] IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
4/15/14 1:05:28.000 PM kernel[0] IO80211Interface::efiNVRAMPublished():
4/15/14 1:05:28.827 PM NetBootClientHelper[115] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:05:28.827 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[115]) Exited with code: 1
4/15/14 1:05:28.827 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 10 seconds
4/15/14 1:05:38.837 PM NetBootClientHelper[118] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:05:38.837 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[118]) Exited with code: 1
4/15/14 1:05:38.837 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 10 seconds
4/15/14 1:05:48.847 PM NetBootClientHelper[119] primaryEthernetAddress: GetMACAddress failed (0x00000005)
4/15/14 1:05:48.847 PM com.apple.launchd[1] (com.apple.NetBootClientHelper[119]) Exited with code: 1
4/15/14 1:05:48.847 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 10 seconds
4/15/14 1:05:54.378 PM com.apple.usbmuxd[44] usbmuxd-327.4 on Feb 12 2014 at 14:54:33, running 64 bit
4/15/14 1:05:54.000 PM kernel[0] jnl: disk0s2: replay_journal: from: 5644800 to: 6251008 (joffset 0x7000)
4/15/14 1:05:54.000 PM kernel[0] jnl: disk0s2: journal replay done.
4/15/14 1:05:54.000 PM kernel[0] hfs: mounted Recovery HD on device disk0s2
4/15/14 1:05:54.951 PM com.apple.launchd[1] (com.apple.NetBootClientHelper) Throttling respawn: Will start in 4 seconds
4/15/14 1:05:54.951 PM KernelEventAgent[68] tid 54485244 type 'hfs', mounted on '/', from '/dev/disk1s2', low disk, very low disk
4/15/14 1:05:54.951 PM KernelEventAgent[68] tid 54485244 display_lowdisk_warning: generating verylowdisk warning for vol
IME, 9 GB is an average .nbi size. The netboot process does not send all of that over the wire though - only the tftp components the Mac requires to netboot. The rest is on the server.
I remember my boot times being somewhere around 20 minutes over a 100Mbps connection. It does matter what OS the nbi is being hosted from. .nbis hosted on a 10.6 server seem to perform much better than the same .nbis hosted on a 10.8 server.
Does you .nbi have a RAM disk? IME that kills performance, drastically increasing boot times.
How can I check if it has a RAM disk?
I'm having issues with netboot as well.
How can I get the log file from the last CMD+V boot session? It flies past really quick and I'd like to be able to read it all carefully.
