Creating new mobiledeviceprofile with API
  • September 6, 2015
  • 35 views
tobiaslinder
I try to create a new mobile device profile by running the command
curl -k -v -u apiuser:apiuserpassword -T nightblock.xml -X POST https://myjssurl:8443/JSSResource/mobiledeviceconfigurationprofiles/name/nightblock
with a xml-File with this content:
<?xml version="1.0" encoding="UTF-8"?> <configuration_profile> <general> <name>nightblock</name> <payloads> <?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-............payloadcontent.................. </payloads> </general> </configuration_profile>
but I always get this output:
Trying 10.0.56.156... Connected to myjssurl (10.0.56.156) port 8443 (#0) TLS 1.1 connection using TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA Server certificate: myjssurl Server certificate: DigiCert SHA2 High Assurance Server CA Server certificate: DigiCert High Assurance EV Root CA Server auth using Basic with user 'apiuser' > POST /JSSResource/mobiledeviceconfigurationprofiles/name/Nachtfilter HTTP/1.1 > Host: jss.anykeyit.ch:8443 > Authorization: Basic YXBpdXNlcjpibGFibGE= > User-Agent: curl/7.43.0 > Accept: / > Content-Length: 2784 > Expect: 100-continue > < HTTP/1.1 100 Continue We are completely uploaded and fine < HTTP/1.1 500 Internal Server Error < X-FRAME-OPTIONS: SAMEORIGIN < Cache-Control: no-store, no-cache, must-revalidate, max-age=0, post-check=0, pre-check=0 < Date: Sun, 06 Sep 2015 22:02:59 GMT < Accept-Ranges: bytes < Server: Restlet-Framework/2.1.7 < Vary: Accept-Charset, Accept-Encoding, Accept-Language, Accept < Content-Type: text/html;charset=UTF-8 < Content-Length: 519 < Connection: close < <html> <head> <title>Status page</title> </head> <body style="font-family: sans-serif;"> <p style="font-size: 1.2em;font-weight: bold;margin: 1em 0px;">Internal Server Error</p> <p>Couldn&apos;t read the XML representation. The processing instruction target matching &quot;[xX][mM][lL]&quot; is not allowed.</p> <p>You can get technical details <a href="http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.5.1">here</a>.<br> Please continue your visit at our <a href="/">home page</a>. </p> </body> </html> * Closing connection 0
Does anyone have an idea what's wrong in my thought process? Thanks in advance for your help!
  • September 6, 2015
You can't create a new JSS object via the API by the name url. You have to use the id number version of the url, and specify the ID as 0.
JSSResources/mobiledeviceconfigurationprofiles/id/0
The JSS will assign the object to the next available id # and name the object with what you put in the XML
tobiaslinder
  • September 7, 2015
Hi Chris
Thanks for your input. I now tried it with this command
curl -k -v -u apiuser:apiuserpassword -T nightblock -X POST https://myjssurl:8443/JSSResource/mobiledeviceconfigurationprofiles/id/0
but I get again this message :-(
TLS 1.1 connection using TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA Server certificate: myjssurl Server certificate: DigiCert SHA2 High Assurance Server CA Server certificate: DigiCert High Assurance EV Root CA Server auth using Basic with user 'apiuser' > POST /JSSResource/mobiledeviceconfigurationprofiles/id/0 HTTP/1.1 > Host: jss.anykeyit.ch:8443 > Authorization: Basic YXBpdXNlcjpibGFibGE= > User-Agent: curl/7.43.0 > Accept: / > Content-Length: 2783 > Expect: 100-continue > < HTTP/1.1 100 Continue We are completely uploaded and fine < HTTP/1.1 500 Internal Server Error < X-FRAME-OPTIONS: SAMEORIGIN < Cache-Control: no-store, no-cache, must-revalidate, max-age=0, post-check=0, pre-check=0 < Date: Mon, 07 Sep 2015 10:27:48 GMT < Accept-Ranges: bytes < Server: Restlet-Framework/2.1.7 < Vary: Accept-Charset, Accept-Encoding, Accept-Language, Accept < Content-Type: text/html;charset=UTF-8 < Content-Length: 519 < Connection: close < <html> <head> <title>Status page</title> </head> <body style="font-family: sans-serif;"> <p style="font-size: 1.2em;font-weight: bold;margin: 1em 0px;">Internal Server Error</p> <p>Couldn&apos;t read the XML representation. The processing instruction target matching &quot;[xX][mM][lL]&quot; is not allowed.</p> <p>You can get technical details <a href="http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.5.1">here</a>.<br> Please continue your visit at our <a href="/">home page</a>. </p> </body> </html> * Closing connection 0
  • September 8, 2021
Hi Chris
Hi Tobiaslinder  :
I also have the same question ~ do you know the solution already?
