I'm having trouble installing iLife '09.mpkg from Casper. The jamf.log
reports that the installer won't install because the system is not 10.5.6
even though it is. Has anyone else had this problem? I'm hoping that
this will also install as an iLife upgrade to my systems running iLife
'08. I've tried creating a dmg of iLife '09 but it won't install and
nothing gets reported in the log about this but I'm assuming it's the same
issue.
John McLaughlin
Technical Support Specialist
Newton Public Schools
