Well
This is a bit of a complicated debacle I am in. I have some old Novell servers that do not support encrypted passwords, so I must have users log in using plain text. So I need to mass edit a plist file on each user account to allow this. Then I want them to click once on a self service policy and have it map the network share that holds the database files. Then in the app's preferences I already have it pointed out where to look.
I looked at the mount_afp command but when I run it in interactive mode it always asks for authentication in the terminal? I can't seem to get a GUI based dialog box. I also need it to wait for about 20 seconds while the user authenticates and then have it launch the app in question.
I have the app configured and it works when I do everything manually, but I need to wrap this up in a one click solution for the end user, so they don't get confused. My other thought is to just create one generic user account that can have access to this database file and then use that generic password in the script and just have it mount under the hood with out the user's actual credentials.
Thanks for any advice.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
blackberry: 913-449-7589
office: 913-627-0351
