Hello JAMF Nation,
My ASUS is now throwing a hissy fit and refuses to load SUS data. Everything worked just fine last Friday and no updates occurred over the weekend.
We have our clients pointed our SUS using either a config profile or command line. We've also tried the direct URL
"http://serverDNS:8088/index.sucatalog".
and
sudo defaults write /Library/Preferences/com.apple.SoftwareUpdate CatalogURL http://serverDNS:8088/content/catalogs/others/index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
The computers have the correct SUS URL according to
defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL
The error:
softwareupdate -l
Software Update Tool
Copyright 2002-2015 Apple Inc.
Finding available software
Can't load data from the Apple Software Update server.
We've tried re-doing the Server setup using "sudo rm /var/db/.ServerSetupDone" and killing cfprefsd, "killall cfprefsd".
We've tried deleting the Server.app, deleting /Library/Server and re-installing the Server.app. No dice.
Any help would be appreciated!
Where I'd start:
On the server:
sudo swupd_syncd -listCatalogs
To see what is available (or it thinks is available), and
sudo swupd_syncd -sync
To force a re-sync with the prime ASUS
@yellow
The catalogs were correct, re-syncing now.
@yellow
The catalogs were all correct, re-syncing now.
Thanks @yellow Looks like ASUS was just missing some updates, re-syncing worked.
Cool beans!
Throw apples sus in the trash and use reposado
Found this discussion on MacRumours forum:
http://forums.macrumors.com/threads/cannot-apply-any-os-x-system-updates-via-app-store.1841892/
But basically THIS worked to get AppStore Software updates to start.
sudo chown -R softwareupdate:_softwareupdate /var/folders/zz/zyxvpxvq6csfxvn*
