Hey.
I'm facing a small issue that I want to fix.
We deploy VMWare Fusion and Virtual machines via Self Service.
Under /Library/Application Support/VMware/VMware Fusion/Shared it saves a file called vmInventory that lists the virtual machines that are shared on the local machine (as they are located in the /Users/Shared/VM folder.
Once a VM is added to the system via Self service I would like to add them to the file automatically.
cat xxx > vmInventory is not working as it not combines both files rather then overwriting the content of the existing vmInventory.
Any other idea?
Thanks in advance.
To add to a file you use >> not >. The single character will overwrite. Double will append.
Thanks Mike.
That done the trick. I only found > on the net.
Cheers
