Have you seen Apple's page on configuring ARD?
http://support.apple.com/kb/ht2370
I've got one that I posted here...hopefully this is what you are trying to do...if you have questions let me know...I still actively use a modified version of this script.
https://support.jamfsoftware.com/discussion.html?id=6682
This is working for me, just pasted new options on original from resource kit.
thanks
# Copyright (c) 2010, JAMF Software, LLC. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of the JAMF Software, LLC nor the
# names of its contributors may be used to endorse or promote products
# derived from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# SUPPORT FOR THIS PROGRAM
# This program is distributed "as is" by JAMF Software, LLC's Resource Kit team. For more
# information or support for the Resource Kit, please utilize the following resources:
# http://list.jamfsoftware.com/mailman/listinfo/resourcekit
# http://www.jamfsoftware.com/support/resource-kit
# Please reference our SLA for information regarding support of this application:
# http://www.jamfsoftware.com/support/resource-kit-sla
# ABOUT THIS PROGRAM
# NAME
# enableARD.sh -- Enable ARD and Configure Remote Management Settings
# SYNOPSIS
# sudo enableARD.sh
# sudo enableARD.sh <mountPoint> <computerName> <currentUsername> <targetUsername>
# If the $targetUsername parameter is specified (parameter 4), this is the account that will be
# granted access to ARD.
# If no parameter is specified for parameter 4, the hardcoded value in the script will be used.
# DESCRIPTION
# This script enables and configures remote management settings for a user. There are a number
# of options that the script is capable of configuring, which should be specified in the privs
# string. Please see the kickstart man page for more information.
# The following options are available in the kickstart application:
# -DeleteFiles
# -ControlObserve
# -TextMessages
# -ShowObserve
# -OpenQuitApps
# -GenerateReports
# -RestartShutDown
# -SendFiles
# -ChangeSettings
# -ObserveOnly
# -mask
# ARD access is granted and priviliges are assigned to an individual account on computers running
# Mac OS X 10.3 and later. It can be used with a hardcoded value in the script, or read in as a
# parameter. Since the Casper Suite defines the first three parameters as (1) Mount Point,
# (2) Computer Name and (3) username, we are using the forth parameter ($4) as the passable
# parameter. We do not use $3 since it may not match up to the username that we want to grant
# access for.
# HISTORY
# Version: 1.1
# - Created by Tedd Herman on August 5th, 2008
# - Modified by Nick Amundsen on August 5th, 2008
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUE FOR "USERNAME" IS SET HERE
targetUsername="admin"
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 4 AND, IF SO, ASSIGN TO "USERNAME"
if [ "$4" != "" ] && [ "$targetUsername" == "" ];then
targetUsername=$4
# DEFINE WHICH PRIVILEGES WILL BE SET FOR THE SPECIFIED USER
privs="-all -agent -DeleteFiles -ControlObserve -TextMessages -OpenQuitApps -GenerateReports -restart -SendFiles -ChangeSettings"
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [ "$targetUsername" != "" ]; then
echo "Enabling Apple Remote Desktop Agent..."
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -allowAccessFor -specifiedUsers
echo "Setting Remote Management Privileges for User: $targetUsername ..."
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -access -on -privs $privs -users $targetUsername
echo "Error: The parameter 'targetUsername' is blank. Please specify a user."
For what it's worth another approach is to use ARD Admin to build a custom ARD Client installer i.e. a pkg file. This will when run on clients then set the desired options.
