I seem to be having a problem building machines. Our first boot script, which we've been using since November, has a section that determines if a machine is a laptop or a desktop, and if it's a laptop it calls down the policy via trigger
# Install VPN if MacBook
/bin/echo "Install VPN if MacBook"
/bin/date
# Detects if this Mac is a laptop or not by checking the model ID for the
word "Book" in the name.
IS_LAPTOP=`/usr/sbin/system_profiler SPHardwareDataType | grep "Model
Identifier" | grep "Book"`
if [[ $shortModel == "MacBook" ]]; then
jamf policy trigger F5VPN
/bin/echo "VPN Not Installed, desktop machine"
Fi
the logs then show it's running that policy, then checks for recurring check-in policies and installs all of them.
+ /bin/echo 'Install VPN if MacBook'
/bin/date
+ /bin/date
Wed Jan 28 12:02:41 PST 2015
/usr/sbin/system_profiler SPHardwareDataType | grep "Model Identifier" |
grep "Book"
++ /usr/sbin/system_profiler SPHardwareDataType
++ grep 'Model Identifier'
++ grep Book
+ IS_LAPTOP=' Model Identifier: MacBookPro11,2'
+ [[ MacBook == MacBook ]]
+ jamf policy trigger F5VPN
Checking for policies triggered by "recurring check-in"...
Executing Policy Citrix Receiver - Aprimo...
Mounting Hoffman to /Volumes/CasperShare...
Verifying package integrity...
Installing Citrix Receiver 11.8.2.dmg...
Closing package...
Submitting log to https:///
Executing Policy F5 VPN Test Group...
Installing F5-VIP.dmg...
Closing package...
Installing F5VPN.pkg_0814.2030.zip...
Successfully installed F5VPN.pkg_0814.2030.zip.
Executing Policy Flash Auto Update...
Running script AutoUpdate Flash...
Script exit code: 0
Script result: /dev/disk1 Apple_partition_scheme
/dev/disk1s1 Apple_partition_map
/dev/disk1s2 Apple_HFS
/private/tmp/flashplayer.uOOa
installer: Package name is Adobe Flash Player
installer: Installing at base path /
installer: Preparing for installation….....
installer: Preparing the disk….....
installer: Preparing Adobe Flash Player….....
installer: Waiting for other installations to complete….....
installer: Configuring the installation….....
installer:
installer: Writing files….....
installer: Running package scripts….....
installer: Validating packages….....
installer: Running installer actions…
installer:
installer: Finishing the Installation….....
installer:
installer: The software was successfully installed......
installer: The install was successful.
"disk1" unmounted.
"disk1" ejected.
Executing Policy Inventory Update...
Executing Policy Trend - Primary Server...
Installing tmsminstall_20.mpkg.zip...
Successfully installed tmsminstall_20.mpkg.zip.
Running Recon...
Retrieving inventory preferences from https://jss/...
Finding extension attributes...
Locating applications...
Locating accounts...
Locating package receipts...
Searching path: /Applications
Locating software updates...
Locating plugins...
Searching path: /Library/Internet Plug-Ins
Locating hard drive information...
Locating hardware information (Mac OS X 10.10.2)...
finally it freezes up at the locating hardware info portion and does not proceed further.
if I take out the FB script then everything is fine. The thing that I don't get is that the same scripts and apps (some may have been updated, FF, Chrome, etc) have been in place since November, and this has only started occurring of the last week or so...
