I am still trying to switch over our Casper instance from a Mac Mini to CentOS 7 servers.
I feel I am close to getting it finished but I am wondering if this is the best config and I want to get a better understanding of how things work before putting it into production:
Our UK Office, all on CentOS 7:
JSS (stores scripts and info on all Macs via MySQL database, correct? but what else does the JSS store)
Netboot Server (stores just the nbi image set required for netbooting Mac clients, correct?).
JDS (stores just the dmg image files for all packages, correct? And set this up as the master).
I am also trying to set-up the JDS as a File Share Distribution Point with afp.
Is that the only way to netboot/netinstall Mac clients on CentOS 7 by setting up afp shares?
I will also need to take this show on the road so to speak to other offices around the world.
Am I correct in thinking that all I will need to do is set-up Netboot servers and JDS (also acting as afp Distribution Points) instances across each of the offices. Each JDS will need to talk to the master JDS in the UK I think.
It would be great to know the architecture of other companies and some gotchas for doing things internationally.
