Casper Suite compatibility with OS X 10.11 El Capitan
  • September 9, 2015
  • 40 replies
  • 149 views
I've been doing some searching around the discussions and knowledge base, but I can't find definitive info on whether Casper Suite is yet compatible with 10.11 El Capitan (beta) and whether there is a timeline when it will be.
I had a user running OS X 10.11 beta trying to enroll using self-enrollment with Quickadd (JSS 9.73), and it would not work. She could not open the Quickadd package, error was "The operation could not be completed. (com.apple.installer.pagecontroller error -1). She is a software engineer and tried to unpack the package various ways with no luck, "Error while extracting archive: (PackageInfo): archived-checksum MD5's do not match (No such file or directory)." She did not believe the error stemmed from 10.11 on her machine. I didn't know there was any problem with 10.11 until I searched the Internets.
Could someone let me know whether the problems she had do (likely) stem from 10.11 incompatibility, or if that would be something else? I am still new to the wonders of OS X management with JAMF, as in I often “wonder” whether I am in over my head. :(
davidacland
  • September 9, 2015
Not sure about that specific issue but you will need to hang on for the next version of the JSS for full 10.11 compatibility AFAIK. You could try a sudo jamf enrol instead assuming the jamf binary successfully installed on the Mac.
  • September 9, 2015
Hey @tony.schaps,
Someone correct me if I'm wrong, but in the past JAMF has offered zero-day compatibility with new OS X releases, so if Phil's "leaked" e-mail is correct, we'll be getting a patch from JAMF on or around September 30.
El Cap is bringing a lot of changes, though. System Integrity Protection (a.k.a. rootless), and among other things, NetBoot servers will now need to be trusted. These changes are big for Casper, which relies heavily on OS X's underlying architecture. So, I'm not surprised at all to hear that your client is having difficulty.
So no, I don't think you're over your head! If you have the option, I would wait until the (presumed) Casper 9.8 binary is released, and then get your client enrolled. Even then, you'll want to upgrade them off the beta and on to the final Release Candidate (again, presumably available on 9/30).
roiegat
  • September 9, 2015
If you look on apple.com/osx the Sept 30 date is on there too.....little more official then the leaked email.
  • September 9, 2015
In my experience, some apps can survive the upgrade to 10.11 with all or most functionality intact, but the app cannot be reinstalled or installed on 10.11.
  • September 9, 2015
Thanks everyone--
Just recently rolled out Casper Suite at our growing software development company. I only knew she'd updated to 10.11 beta because our Aerohive HiveManager detected it. Not sure it was a good idea to upgrade to 10.11 beta in a production environment, but not sure software engineers care what TechOps thinks :)
We're really trying to get our holdouts to get enrolled, so waiting for Sept. 30 is undesirable. All of this talk has put a bit of fear in me what we can expect with El Capitan.
@davidacland If the Quickadd wouldn't launch, then the jamf binary could not be installed, or do I understand that process incorrectly?
Thanks again--
davidacland
  • September 9, 2015
@tony.schaps it will depend what stage the installer fails. If it starts but then fails to actually enroll, it might have got far enough to get the jamf binary on there.
Failing that you could grab the binary from another Mac, then run it and see if you can get it enrolled.
That all being said, I'd probably wipe the Mac, re-install 10.10.5, enroll and then setup the beta 10.11 installer as restricted software.
  • September 10, 2015
You could consider adding El Cap to restricted software, with disclaimer message, I've used
Due to recently discovered compatibility issues, YouCoName IT recommends that staff do not upgrade to OSX 10.11 El Capitan at this time. We fully expect these OSX compatibility issues to be resolved in short order by Apple in the coming OSX update.
Installed the GM of 10.11 today and Casper apps run fine, JSS picks up OS level in the Inventory update.
Packages being pushed out work, still testing for issues.
MS Lync does not work with 10.11 GM
@dmw3 good info, did you try launching the Quickadd package on 10.11 GM, or did you upgrade an existing installation? thx
@tony.schaps It was an in place upgrade, will be running a Quickadd.pkg test tomorrow when I redo a computer.
@dmw3 Great, I will look forward to hearing the result, please report back. Thanks!
@davidacland The Quickadd package would not even launch for this person, and she said it was not Gatekeeper related (i.e. she knows how to handle that, and it was also in our instructions). We're evolving from a small shop, and rolling out Casper is a step forward, but these devs have managed their own machines themselves the past few years. Requiring one to re-image is not something I'd probably get support for as long as a dev is doing a good job with their tools.
firstworldproblems
Thanks
@dmw3 Which part of MS Lync isn't working for you? I'm able to fire up MS Lync and login without issue.
@dmw3 I have experienced the same issue with MS Lync crashing after an OS upgrade to Yosemite. The fix is fairly simple...
rm ~/Library/Preferences/com.microsoft.Lync.plist
rm ~/Library/Preferences/ByHost/MicrosoftLyncRegistrationDB.*
rm -rf ~/Documents/Microsoft User Data/Microsoft Lync Data/
Killall cfpfefsd
This should completely remove any Lync settings and allow you to reconfigure it.
@tony.schaps I am able to get our JAMF binaries on to a 10.11 GM machine but I cannot use a QuickAdd directly from the enrollment page or the from Recon. I took our standard QuickAdd and opened it inside of Composer. I moved the standard install location from /usr/sbin and put them in /tmp (updating permissions to be owned by root:wheel). I then added a line to move the binaries to /usr/sbin and left everything else in place. With these settings it worked without issue.
JSS 9.65
emily
Oh it's not just me, @andrew.nicholas! I've been trying to get the QuickAdd to install all morning to no avail. Was just about to dig into the QuickAdd package when you posted this. It's nice to know I'm not suffering alone.
@emilykausalik Glad to help! I'm also noticing that Casper Imaging is no bueno as well. 9.65 (Prod) crashes out right and 9.73 (Test) will try to start but throws a NilObject error and then crashes. Self Service once enrolled works great at least so I can offer a solution to any outliers that just HAVE to run 10.11.
All tests done on a fresh 10.11GM install.
As an aside, I've also noticed some changes with createmobileaccount. It no longer throws the two ignorable errors when successfully completing, so thats cool.
emily
So basically the JSS has been updated but none of the Suite software has? That's the impression I'm getting, anyway.
scottb
We're running the beta of the next version. While I guess we can't talk about it here, I would think that you are going to see things change with this release.
There are a lot of changes in 10.11 and I would recommend at least signing up for the betas as you can see what's going on over there and discuss.
I was Wunderding if it was just me.
The Suite Software worked around beta 3 or 4 then stopped at the next beta release.
Hope to see a fix to this shortly.
@bracyj_SAIC Thanks, had removed all but the ByHost files, so Lync now works. I will have to get a script up to remove those files on an upgrade to 10.11.
emily
  • September 11, 2015
Hey @andrew.nicholas any chance you can share the modifications you made to the postinstall script in the QuickAdd.pkg?
@emilykausalik Sure thing!
This is how I delivered the binaries:
This is how I moved them into place:
I just imaged a machine in Imaging (9.72) using a 10.11 GM base created in AutoDMG, and for the most part it seems to work as expected. The machine does enroll in the JSS (using the automatic enrollment in the configuration), and updates inventory, though with a minor error. Self Service lets me auth and presents a list of policies but will not run anything.
