Deploying LogMeIn via Casper
  • September 11, 2015
  • 6 replies
  • 20 views
I found several sparse tidbits on deploying LogMeIn, so I figured I'd share.
The script should be a simple drop-in to JSS 9.7 to deploy the LogMeIn software. It downloads the latest version of the client, rather than having you package a stale version. You could fairly easily modify it if you want ot manually control versions, but this was fine for our needs.
To use:
1. Add to Casper Admin/JSS like any normal script
2. In your Policy, set varible #4 (deployid) to be your Deployment ID (see note)
3. Deploy silently or advertise via Self Service
Note
In order to get a Deployment ID, you need to be using LogMeIn Central.
1. Log in to Central
2. Create a new Deployment
3. The ID is the "c" URL parameter in the link that the deployment will generate
#   LogMeIn for Mac silent deployment script
#   In order to use, you must be a subscriber of LogMeIn Central
#   To get a Deploy ID, log in to Central, click Deployments, then create a new one
#   Customize the settings as you see fit
#   The Deploy ID is part of the URL that is generated
#   ex. https://secure.logmein.com/i?l=en&c=xyz
#   xyz is the Deploy ID
#   Tested on OS X 10.10.5 (Yosemite) with JSS 9.73
#   Set the deploy ID via command line argument
DEPLOYID=$4  #Change to 1 if not using Casper Suite
echo "Deploy ID is: $DEPLOYID"
echo "Running LogMeIn host install"
# Change working directory to /tmp
cd /tmp
# Clean up any existing LogMeIn install files first
rm -rf /tmp/LMI
# Create working folder, LMI doesn't like being in the root of /tmp
mkdir LMI
cd LMI
# Download LogMeIn Mac  software
echo "Downloading LogMeIn installer"
curl -O https://secure.logmein.com/LogMeInInstallerMac.zip
# Extract the installer
echo "Unzipping LogMeIn installer"
unzip LogMeInInstallerMac.zip
# Get the versioned file name
FILE="$(ls | grep LogMeIn*.app)"
echo "File name is: $FILE"
# Write the deploy ID as an extended attribute on the install package
echo "Setting deploy ID as attribute"
xattr -w com.logmein.deployid $DEPLOYID "$FILE"
echo "Reading deploy ID attribute to confirm"
xattr -p com.logmein.deployid "$FILE"
# Run the silent install
echo "Running the LogMeIn installer"
./"$FILE"/Contents/MacOS/Lili --silent
# Remove temp files
echo "Cleaning up temp files"
rm -rf /tmp/LMI
echo "Exiting with success"
  • January 12, 2016
AMAZING!
Thanks
  • 7 replies
  • June 27, 2016
has anyone used this with 10.11?
had a package with installer app and post flight script close to this. no longer works in 10.11for some reason.
thanks
Paul
  • August 15, 2016
Good day all. I wanted to update this to let everyone know that I was able to make this work on 10.11.6 with JSS 9.93.1469132907.c : hosted server. I was able to run it as is. I had a little confusion on the "In your Policy, set variable #4 (deployid) to be your Deployment ID (see note)" I had to make a batch file within logmein central and then copy the unique ID for Line 4. Hope this helps anyone else out there trying to deploy LMI via a deployment package from LMI Central.
  • January 31, 2018
I wanted to post that I have made use of this today and the script works fine. Thank you for sharing this with the group.
  • 4 replies
  • November 16, 2018
I got the command from logmeincentral below:
msiexec.exe /i LogMeIn.msi DEPLOYID=01_fxbvgtml9pcdbf7q3sq04iw3u3p7zfny2vrmp INSTALLMETHOD=5 FQDNDESC=1
so is my deploy ID is 01? or is it 01_fxbvgtml9pcdbf7q3sq04iw3u3p7zfny2vrmp
and do I modify the script below to be like this?
DEPLOYID=$01_fxbvgtml9pcdbf7q3sq04iw3u3p7zfny2vrmp #Change to 1 if not using Casper Suite
EDIT: I got it to work! The deployID is the entire string so in this example, DeployID is: 01_fxbvgtml9pcdbf7q3sq04iw3u3p7zfny2vrmp and I was confused as another poster mentioned of the ID4 in the policy. To clarify for those that are new to JAMF, when you create a new policy, and point to this new script, at the section where Parameter 4 is where you enter the DeployID string.
  • November 17, 2018
Guys this is awesome! Thanks so much for everyone that has given their feedback and various tips here.
Install works without an issue. However, I still run into the issue where I have to approve accessibility control via sysprefs. Has anyone managed to identify a way to automate this?
