I've got 3-4 clients that will install policies but fail somewhere in recon after install. When I run recon from the command line, this is what I get.
bash-3.2$ sudo jamf checkJSSConnection
Password:
Checking availability of https://casper.server.com/...
The JSS is available.
bash-3.2$ sudo jamf recon
Retrieving inventory preferences from https://casper.server.com/...
Finding extension attributes...
Locating hard drive information...
Locating hardware information (Mac OS X 10.8.5)...
Locating accounts...
Locating applications...
Searching path: /Applications
Locating package receipts...
Gathering application usage information...
Submitting data to https://casper.server.com/...
There was an error.
Message has no content
bash-3.2$
I've reimaged, unmanaged and ran the -removeFramework command and then readded the machine and it still behaves the same way. The rest of the clients are seeming to behave fine, which is why I think it's the clients rather than the JSS. Has anyone seen something like this and have any advice on what else to check on?
