I have started trying to use the "new" Apple deployment method of distributing managed mobile apps through Casper. I am running 9.4.
I am trying to distribute Notability. I have about 1400 iPad users, and purchased 400 licenses; many users already have it installed, which is why I only bought a smaller amount thinking I would add more later, if needed. I have invited the users to VPP, added them to the scope and assigned the app in VPP Assignments under the Users tab.
The users that have accepted the invitation see Notability in self service. When the tap "Install" in self service, it spins and spins and spins. When they go to tap a free app in self-service, a pop up appears and they are prompted to install.
I believe I have everything setup correctly, but I am apparently missing something.
Thanks for your help.
