Hello,
Need help on reissuing the recovery keys for 10.13.X. In High sierra it’s getting error " Error: Missing user name." & “Unable to unlock or authenticate to FileVault error”, were as in system preferences users are FV enabled including admin ( Iguess they shuld should to authorized to unlock FV).
Running script Redirecting and Reissue FV Key...
Script exit code: 0
Script result: Prompting administrator for their login password.
36:265: execution error: An error of type -10810 has occurred. (-10810)
Issuing new recovery key
Error: Password is required.
Error: User could not be authenticated.
Error: Unable to unlock or authenticate to FileVault.
Flushing System Caches...
Error: Internal error.
Checking for patches...
No patch policies were found.
Running Recon...
Retrieving inventory preferences from
https://xxx.jamfcloud.com/...
we are using https://github.com/JAMFSupport/FileVault2_Scripts/blob/master/reissueKey.sh
(I’m new to Jamf ☺ )
