Offline imaging- things go wrong at the end in a couple ways
  • November 26, 2013
  • 0 replies
  • 13 views
Forum|alt.badge.img+19
HI JAMF nation- I've been having some strange issues with imaging since 8.73 came out, and the symptoms are present in 8.73, 9.2, and 9.21. I'm wondering if anyone else has seen this and found a better solution than what I'm working on right now.
First of all, the problem only occurs if you're using 'Offline Imaging' (i.e. you're using a distribution point on a local disk rather than a network share) with a network connection present. We use that combination to minimize network traffic during the imaging process, while still being able to install software that requires access to the network . . .and bind the machines to AD automatically as well. The problems begin after the reboot when the quickadd package runs. Policies begin running from multiple jamf processes, and they step on each other's operations, i.e. 2 (or more) jamf processes try to add the startup launchd simultaneously. Also, the adobeinstall account gets deleted before the first run script is complete, and operations continue even after the reboot command is sent, which can interrupt them and result in a non-booting machine.
Here's a representative jamf.log showing the timing issues and multiple processes:
2013-11-25 8:58:4 Formatted Macintosh HD
Mon Nov 25 08:58:04 No Name jamf[2423]: Installing Desktop and Screensaver Images.dmg...
Mon Nov 25 08:58:07 No Name jamf[2482]: Installing HDS User Logo.dmg...
Mon Nov 25 08:58:09 No Name jamf[2540]: Installing ADPassMon 1.9.1_v2.dmg...
Mon Nov 25 08:58:12 No Name jamf[2598]: Installing Cache Network Home Script v7.dmg...
Mon Nov 25 08:58:15 No Name jamf[2656]: Installing Cisco WebEx Removal Tool.pkg...
Mon Nov 25 08:58:20 No Name jamf[2656]: Successfully installed Cisco WebEx Removal Tool.pkg.
Mon Nov 25 08:58:21 No Name jamf[2702]: Installing Citrix Receiver HDS Settings.dmg...
Mon Nov 25 08:58:24 No Name jamf[2826]: Installing CocoaDialog.dmg...
Mon Nov 25 08:58:26 No Name jamf[2884]: Installing ComboFix_10.8.5.dmg...
Mon Nov 25 08:58:29 No Name jamf[2942]: Installing CommunicatorSetup 1.0.dmg...
Mon Nov 25 08:58:32 No Name jamf[3066]: Installing dockutil installer 1.0.pkg...
Mon Nov 25 08:58:37 No Name jamf[3066]: Successfully installed dockutil installer 1.0.pkg.
Mon Nov 25 08:58:38 No Name jamf[3112]: Installing Firefox 24.0.dmg...
Mon Nov 25 08:58:41 No Name jamf[3170]: Installing GarageBand_6.0.5.dmg...
Mon Nov 25 08:59:01 No Name jamf[3228]: Installing HDS Utilities 1.1.1.dmg...
Mon Nov 25 08:59:04 No Name jamf[3286]: Installing HDS_Bookmarks.dmg...
Mon Nov 25 08:59:07 No Name jamf[3411]: Installing HDS_Dock_2.3.dmg...
Mon Nov 25 08:59:10 No Name jamf[3535]: Installing HDS_Finder_Preferences.dmg...
Mon Nov 25 08:59:12 No Name jamf[3659]: Installing HDS_Mac_Documentation_1.3.dmg...
Mon Nov 25 08:59:15 No Name jamf[3783]: Installing HDS_Story_1.2.0.dmg...
Mon Nov 25 08:59:19 No Name jamf[3841]: Installing iMovie_9.0.9.dmg...
Mon Nov 25 08:59:34 No Name jamf[3899]: Installing iPhoto_9.4.3.dmg...
Mon Nov 25 08:59:50 No Name jamf[3957]: Installing Outlook User Template 1.4.2.dmg...
Mon Nov 25 08:59:53 No Name jamf[4015]: Installing setregproptool installer 2.0.dmg...
Mon Nov 25 08:59:56 No Name jamf[4073]: Installing Setup_Assistant_plist_10.8.5.dmg...
Mon Nov 25 08:59:58 No Name jamf[4197]: Installing Submit User Info v3.dmg...
Mon Nov 25 09:00:01 No Name jamf[4255]: Installing Cache EMEA_CV9_SP7.3 Installer.dmg...
Mon Nov 25 09:00:04 No Name jamf[4313]: Installing HDS MSO Templates 2013.dmg...
Mon Nov 25 09:00:07 No Name jamf[4438]: Installing Set Desktop Pattern.dmg...
Mon Nov 25 09:00:10 No Name jamf[4562]: Installing Set HDS Screensaver.dmg...
Mon Nov 25 09:00:13 No Name jamf[4701]: Creating .AppleSetupDone...
Mon Nov 25 09:03:57 usscc-emeatest2 jamf[4777]: Could not connect to the JSS. Looking for cached policies...
Mon Nov 25 09:04:01 usscc-emeatest2 jamf[6337]: Setting home page to 'myhds.hds.com' for Existing Users and User Templates
Mon Nov 25 09:04:03 usscc-emeatest2 jamf[6632]: Installing firstboot_curtain.sh.pkg...
Mon Nov 25 09:04:05 usscc-emeatest2 jamf[6632]: Successfully installed firstboot_curtain.sh.pkg.
Mon Nov 25 09:04:05 usscc-emeatest2 jamf[6707]: Installing set_manual_proxy_and_location_EMEA_v1.pkg...
Mon Nov 25 09:04:09 usscc-emeatest2 jamf[6707]: Successfully installed set_manual_proxy_and_location_EMEA_v1.pkg.
Mon Nov 25 09:04:09 usscc-emeatest2 jamf[6834]: Installing Set Hostname.pkg...
Mon Nov 25 09:04:11 usscc-emeatest2 jamf[6834]: Successfully installed Set Hostname.pkg.
Mon Nov 25 09:04:11 usscc-emeatest2 jamf[6875]: Installing FileVaultMaster.keychain.pkg...
Mon Nov 25 09:04:13 usscc-emeatest2 jamf[6875]: Successfully installed FileVaultMaster.keychain.pkg.
Mon Nov 25 09:04:14 usscc-emeatest2 jamf[6916]: Installing Adobe Reader X 10.1.4.pkg...
Mon Nov 25 09:04:29 usscc-emeatest2 jamf[6916]: Successfully installed Adobe Reader X 10.1.4.pkg.
Mon Nov 25 09:04:29 usscc-emeatest2 jamf[8645]: Installing Apple Software Updates Profile.pkg...
Mon Nov 25 09:04:31 usscc-emeatest2 jamf[8645]: Successfully installed Apple Software Updates Profile.pkg.
Mon Nov 25 09:04:31 usscc-emeatest2 jamf[8688]: Installing Citrix Receiver 11.6.pkg...
Mon Nov 25 09:04:43 usscc-emeatest2 jamf[8688]: Successfully installed Citrix Receiver 11.6.pkg.
Mon Nov 25 09:04:44 usscc-emeatest2 jamf[8860]: Installing Communicator Installer.pkg...
Mon Nov 25 09:04:51 usscc-emeatest2 jamf[8860]: Successfully installed Communicator Installer.pkg.
Mon Nov 25 09:04:51 usscc-emeatest2 jamf[8910]: Installing CreateItLimitedUser_v2.pkg...
Mon Nov 25 09:05:04 usscc-emeatest2 jamf[8910]: Successfully installed CreateItLimitedUser_v2.pkg.
Mon Nov 25 09:05:04 usscc-emeatest2 jamf[8966]: Installing CreateLionUser _itsupport_V2.pkg...
Mon Nov 25 09:05:17 usscc-emeatest2 jamf[8966]: Successfully installed CreateLionUser _itsupport_V2.pkg.
Mon Nov 25 09:05:18 usscc-emeatest2 jamf[9022]: Installing Custom Settings Profile v2.pkg...
Mon Nov 25 09:05:20 usscc-emeatest2 jamf[9022]: Successfully installed Custom Settings Profile v2.pkg.
Mon Nov 25 09:05:20 usscc-emeatest2 jamf[9066]: Installing Duti 1.5.1.pkg...
Mon Nov 25 09:05:22 usscc-emeatest2 jamf[9066]: Successfully installed Duti 1.5.1.pkg.
Mon Nov 25 09:05:23 usscc-emeatest2 jamf[9104]: Installing EMEA_CV9_SP7.3.pkg...
Mon Nov 25 09:10:41 usscc-emeatest2 jamf[9104]: Successfully installed EMEA_CV9_SP7.3.pkg.
Mon Nov 25 09:10:41 usscc-emeatest2 jamf[51988]: Installing Enable Java Web Plugin at Login.pkg...
Mon Nov 25 09:10:44 usscc-emeatest2 jamf[51988]: Successfully installed Enable Java Web Plugin at Login.pkg.
Mon Nov 25 09:10:44 usscc-emeatest2 jamf[52140]: Installing Energy_Saver_Profile_v2.pkg...
Mon Nov 25 09:10:46 usscc-emeatest2 jamf[52140]: Successfully installed Energy_Saver_Profile_v2.pkg.
Mon Nov 25 09:10:46 usscc-emeatest2 jamf[52297]: Installing Flash 11.8.800.168.pkg...
Mon Nov 25 09:10:55 usscc-emeatest2 jamf[52297]: Successfully installed Flash 11.8.800.168.pkg.
Mon Nov 25 09:10:56 usscc-emeatest2 jamf[52882]: Installing Gatekeeper Profile.pkg...
Mon Nov 25 09:10:58 usscc-emeatest2 jamf[52882]: Successfully installed Gatekeeper Profile.pkg.
Mon Nov 25 09:10:58 usscc-emeatest2 jamf[52924]: Installing HDS Root Cert Installer 1.3.pkg...
Mon Nov 25 09:11:00 usscc-emeatest2 jamf[52924]: Successfully installed HDS Root Cert Installer 1.3.pkg.
Mon Nov 25 09:11:00 usscc-emeatest2 jamf[52969]: Installing HDS_LocationChanger_2.5.pkg...
Mon Nov 25 09:11:03 usscc-emeatest2 jamf[52969]: Successfully installed HDS_LocationChanger_2.5.pkg.
Mon Nov 25 09:11:03 usscc-emeatest2 jamf[53013]: Installing HewlettPackardPrinterDrivers_2.14.pkg...
Mon Nov 25 09:12:41 usscc-emeatest2 jamf[53013]: Successfully installed HewlettPackardPrinterDrivers_2.14.pkg.
Mon Nov 25 09:12:41 usscc-emeatest2 jamf[57861]: Installing Install iTunes.pkg...
Mon Nov 25 09:13:10 usscc-emeatest2 jamf[57861]: Successfully installed Install iTunes.pkg.
Mon Nov 25 09:13:10 usscc-emeatest2 jamf[58036]: Installing JavaForOSX2013-004.pkg...
Mon Nov 25 09:13:15 usscc-emeatest2 jamf[58036]: Successfully installed JavaForOSX2013-004.pkg.
Mon Nov 25 09:13:15 usscc-emeatest2 jamf[58115]: Installing Login Items Profile.pkg...
Mon Nov 25 09:13:18 usscc-emeatest2 jamf[58115]: Successfully installed Login Items Profile.pkg.
Mon Nov 25 09:13:18 usscc-emeatest2 jamf[58162]: Installing McAfee_Agent_4_8_Patch_1.pkg...
Mon Nov 25 09:13:20 usscc-emeatest2 jamf[58162]: Successfully installed McAfee_Agent_4_8_Patch_1.pkg.
Mon Nov 25 09:13:20 usscc-emeatest2 jamf[58201]: Installing Office Installer HDS SP3.pkg...
Mon Nov 25 09:13:49 usscc-emeatest2 jamf[58201]: Successfully installed Office Installer HDS SP3.pkg.
Mon Nov 25 09:13:49 usscc-emeatest2 jamf[58353]: Installing RicohPrinterDrivers_2.3.pkg...
Mon Nov 25 09:14:01 usscc-emeatest2 jamf[58353]: Successfully installed RicohPrinterDrivers_2.3.pkg.
Mon Nov 25 09:14:01 usscc-emeatest2 jamf[59138]: Installing Silverlight 5.1.10411.0.pkg...
Mon Nov 25 09:14:04 usscc-emeatest2 jamf[59138]: Successfully installed Silverlight 5.1.10411.0.pkg.
Mon Nov 25 09:14:04 usscc-emeatest2 jamf[59202]: Installing UFRII_LT_LIPS_LX_Installer.pkg...
Mon Nov 25 09:15:15 usscc-emeatest2 jamf[59202]: Successfully installed UFRII_LT_LIPS_LX_Installer.pkg.
Mon Nov 25 09:15:15 usscc-emeatest2 jamf[65351]: Installing VPN_Recon_launchd_1.3.pkg...
Mon Nov 25 09:15:18 usscc-emeatest2 jamf[65351]: Successfully installed VPN_Recon_launchd_1.3.pkg.
Mon Nov 25 09:15:18 usscc-emeatest2 jamf[65395]: Installing WebEx Meeting Center.pkg...
Mon Nov 25 09:15:21 usscc-emeatest2 jamf[65395]: Successfully installed WebEx Meeting Center.pkg.
Mon Nov 25 09:15:21 usscc-emeatest2 jamf[65471]: Installing AdbeRdrUpd1017.pkg...
Mon Nov 25 09:15:43 usscc-emeatest2 jamf[65471]: Successfully installed AdbeRdrUpd1017.pkg.
Mon Nov 25 09:15:43 usscc-emeatest2 jamf[66932]: Installing java6_webplugin_enabler_1.2.pkg...
Mon Nov 25 09:15:45 usscc-emeatest2 jamf[66932]: Successfully installed java6_webplugin_enabler_1.2.pkg.
Mon Nov 25 09:15:45 usscc-emeatest2 jamf[66978]: Installing Office 2011 14.3.8 Update.pkg...
Mon Nov 25 09:17:04 usscc-emeatest2 jamf[66978]: Successfully installed Office 2011 14.3.8 Update.pkg.
Mon Nov 25 09:17:04 usscc-emeatest2 jamf[70204]: Installing VSM950-RTW-1641.pkg...
Mon Nov 25 09:18:16 usscc-emeatest2 jamf[70204]: Successfully installed VSM950-RTW-1641.pkg.
Mon Nov 25 09:18:16 usscc-emeatest2 jamf[70968]: Installing ActivateSpotlight.pkg...
Mon Nov 25 09:18:18 usscc-emeatest2 jamf[70968]: Successfully installed ActivateSpotlight.pkg.
Mon Nov 25 09:18:19 usscc-emeatest2 jamf[71012]: Installing QuickAdd_8.7.pkg...
Mon Nov 25 09:18:23 usscc-emeatest2 jamf[71074]: Creating user <redacted>...
Mon Nov 25 09:18:42 usscc-emeatest2 jamf[71151]: Enforcing management framework...
Mon Nov 25 09:18:42 usscc-emeatest2 jamf[71151]: Enforcing scheduled tasks...
Mon Nov 25 09:18:42 usscc-emeatest2 jamf[71151]: Adding launchd task com.jamfsoftware.task.4...
Mon Nov 25 09:18:42 usscc-emeatest2 jamf[71151]: Installing Self Service plug-in Communicator...
Mon Nov 25 09:18:43 usscc-emeatest2 jamf[71151]: Installing Self Service plug-in myHDS ...
Mon Nov 25 09:18:43 usscc-emeatest2 jamf[71151]: Installing Self Service plug-in The Loop...
Mon Nov 25 09:20:51 usscc-emeatest2 jamf[71074]: Enforcing management framework...
Mon Nov 25 09:20:52 usscc-emeatest2 jamf[71074]: Enforcing scheduled tasks...
Mon Nov 25 09:20:52 usscc-emeatest2 jamf[71074]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.4.plist...
Mon Nov 25 09:20:52 usscc-emeatest2 jamf[71074]: Adding launchd task com.jamfsoftware.task.4...
Mon Nov 25 09:20:52 usscc-emeatest2 jamf[71074]: Existing plug-in, 2.plist, is up to date.
Mon Nov 25 09:20:52 usscc-emeatest2 jamf[71074]: Existing plug-in, 4.plist, is up to date.
Mon Nov 25 09:20:52 usscc-emeatest2 jamf[71074]: Existing plug-in, 6.plist, is up to date.
Mon Nov 25 09:20:52 usscc-emeatest2 jamf[71012]: Successfully installed QuickAdd_8.7.pkg.
Mon Nov 25 09:20:53 usscc-emeatest2 jamf[71802]: Deleting user adobeinstall...
Mon Nov 25 09:20:53 usscc-emeatest2 jamf[71802]: Deleting home directory for adobeinstall...
Mon Nov 25 09:21:06 usscc-emeatest2 jamf[72045]: Binding usscc-emeatest2 to corp.hds.com...
Mon Nov 25 09:21:08 usscc-emeatest2 jamf[72045]: The username (itdecm) and password provided for the domain (corp.hds.com) was not valid. (Attempt 1)
Mon Nov 25 09:22:01 usscc-emeatest2 jamf[72045]: Bound to Active Directory (corp.hds.com)
Mon Nov 25 09:22:05 usscc-emeatest2 jamf[72289]: Checking for policies triggered by "startup"...
Mon Nov 25 09:22:05 usscc-emeatest2 jamf[72289]: Upgrading jamf binary...
Mon Nov 25 09:22:19 usscc-emeatest2 jamf[72289]: Upgrading jamf agent...
Mon Nov 25 09:22:20 usscc-emeatest2 jamf[72289]: Upgrading Self Service.app...
Mon Nov 25 09:22:42 usscc-emeatest2 jamf[72289]: Executing Policy Cache MountSMBHome_Vx to HDS Folder...
Mon Nov 25 09:22:43 usscc-emeatest2 jamf[72289]:    Installing Cache Network Home Script v7.dmg...
Mon Nov 25 09:23:10 usscc-emeatest2 jamf[72289]: Executing Policy Cache submit_user_info.sh to HDS Folder...
Mon Nov 25 09:23:10 usscc-emeatest2 jamf[72289]:    Uninstalled Submit User Info.dmg.
Mon Nov 25 09:23:11 usscc-emeatest2 jamf[72289]:    Installing Submit User Info v3.dmg...
Mon Nov 25 09:23:20 usscc-emeatest2 jamf[73299]: The management framework will be enforced as soon as all policies are done executing.
Mon Nov 25 09:23:21 usscc-emeatest2 jamf[73303]: Checking for policies triggered by "any"...
Mon Nov 25 09:23:22 usscc-emeatest2 jamf[73303]: Executing Policy Cache submit_user_info.sh to HDS Folder...
Mon Nov 25 09:23:22 usscc-emeatest2 jamf[73303]:    Uninstalled Submit User Info.dmg.
Mon Nov 25 09:23:24 usscc-emeatest2 jamf[73303]:    Installing Submit User Info v3.dmg...
Mon Nov 25 09:23:35 usscc-emeatest2 jamf[72289]: Executing Policy Dockutil 1.1.4 Update...
Mon Nov 25 09:23:35 usscc-emeatest2 jamf[72289]:    Uninstalled dockutil installer 1.0.pkg.
Mon Nov 25 09:23:37 usscc-emeatest2 jamf[72289]:    Installing dockutil_1.1.4.dmg...
Mon Nov 25 09:23:49 usscc-emeatest2 jamf[73303]: Executing Policy Dockutil 1.1.4 Update...
Mon Nov 25 09:23:50 usscc-emeatest2 jamf[73303]:    Uninstalled dockutil installer 1.0.pkg.
Mon Nov 25 09:23:51 usscc-emeatest2 jamf[73303]:    Installing dockutil_1.1.4.dmg...
Mon Nov 25 09:24:01 usscc-emeatest2 jamf[72289]: Executing Policy ensure SSH is running...
Mon Nov 25 09:24:01 usscc-emeatest2 jamf[72289]: Executing Policy Safari Lockfile Cleanup...
Mon Nov 25 09:24:02 usscc-emeatest2 jamf[72289]: Executing Policy Update LoginWindow Text...
Mon Nov 25 09:24:02 usscc-emeatest2 jamf[72289]: Adding launchd task com.jamfsoftware.task.checkForTasks...
Mon Nov 25 09:24:03 usscc-emeatest2 jamf[74387]: The management framework will be enforced as soon as all policies are done executing.
Mon Nov 25 09:24:16 usscc-emeatest2 jamf[73303]: Executing Policy ensure SSH is running...
Mon Nov 25 09:24:16 usscc-emeatest2 jamf[73303]: Executing Policy Safari Lockfile Cleanup...
Mon Nov 25 09:24:17 usscc-emeatest2 jamf[73303]: Executing Policy Update LoginWindow Text...
Mon Nov 25 09:24:18 usscc-emeatest2 jamf[73303]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.checkForTasks.plist...
Mon Nov 25 09:24:18 usscc-emeatest2 jamf[73303]: Adding launchd task com.jamfsoftware.task.checkForTasks...
Mon Nov 25 09:24:19 usscc-emeatest2 jamf[74549]: Enforcing management framework...
Mon Nov 25 09:24:19 usscc-emeatest2 jamf[74549]: Enforcing scheduled tasks...
Mon Nov 25 09:24:19 usscc-emeatest2 jamf[74549]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.4.plist...
Mon Nov 25 09:24:19 usscc-emeatest2 jamf[74549]: Adding launchd task com.jamfsoftware.task.4...
Mon Nov 25 09:24:20 usscc-emeatest2 jamf[74549]: Existing plug-in, 2.plist, is up to date.
Mon Nov 25 09:24:20 usscc-emeatest2 jamf[74549]: Existing plug-in, 4.plist, is up to date.
Mon Nov 25 09:24:20 usscc-emeatest2 jamf[74549]: Existing plug-in, 6.plist, is up to date.
Mon Nov 25 09:31:57 usscc-emeatest2 jamf[76992]: Reboot. Immediately.
Mon Nov 25 09:31:57 usscc-emeatest2 jamf[76992]: Rebooting computer immediately...
Anyone else dealing with this situation out there? I've been working with JAMF support on this and they are working on a fix, but it may not be released for 8.73. I'd rather not have to upgrade to 9 yet to fix this, so I'd like to find solution for 8 as well. Any ideas?
