Is there a way for me to use Managed preferences or Configuration profiles for the "Show Status Bar" option under the view menu to be default for everyone? I can't seem to find a setting for that.
Thanks.
Thanks.
OK I found that the command "defaults write com.apple.finder ShowStatusBar -bool true" will work. Is there a way to incorporate that into a configuration profile? I am not real familiar with them but imagine there has to be way to do that.
Ideas anyone?
@macboy You'll need to do a Configuration Profile Custom Setting using the com.finder.apple domain. You can just include the setting(s) you want to adjust.
@spraguga What do you mean just include the setting you want to adjust? I see an upload for a plist file. Not sure what i need to do.
I am not very familiar with Configuration Profiles and don't use them often but would really like to start getting a handle on them.
Thanks for the input so far.
@macboy
1. Copy the com.apple.finder.plist to your desktop
2. Convert to XML using: sudo plutil -convert xml1 /path/to/com.someplist.plist
3. Upload the plist and only include the arrays/keys you want to apply
4. Then test, test, test
