Clean Up & Deleting Old Packages
  • April 30, 2014
  • 17 views
Forum|alt.badge.img+22
Searched around a bit but no luck finding my solution yet. I want to reduce my footprint in the JSS for the amount of space my packages are taking up as I prepare to add a distribution point with Amazon AWS. Packages folder is nearly 77 GB. I deleted a bunch of un-needed packages from Casper Admin, save and replicate, all looks good in CA. I go to the Packages folder in the CasperShare and the packages are all there and the size is still 77 GB. What gives?
Best answer by TomDay
Took almost an hour to final show the correct size, also exited out of Casper Admin to unmount the share. Looks OK now
1 reply
  • April 30, 2014
