Any early reports of problems? My test environment seemed to go okay...
It was a smooth upgrade in production & testing.
Windows Server 2012 R2, Java 8 Update 60
well, mine didn't go so well in prod, testing was fine.
i put java 8 and the ice in, upgraded to 9.8... and now I can't get to the web interface. just keeps redirecting me to the generic OS X website.
That sucks :/
The only issue (just noticed) is that the "Scripts contain invalid references to /usr/sbin/jamf" notification won't go away. I have nothing pointing to /usr/sbin/jamf. I have stuff using /usr/sbin, but not the sbin/jamf.
We did the upgrade from 9.73 to 9.8 (running OS X 10.10.5) without problems. But a curious new issue affected some computers during the lunch break: the logged in user was logged out after x time of inactivity. Those with unsaved documents weren't, because a modal dialog stopped it.
Finally I found out, that a configuration profile was altered on a way I can't explain. I edited one yesterday after the JSS update to update the banner with the new JSS version. But at "Configuration Profiles > Login-Window > Options >" Log out users after 30 minutes of inactivity was checked...
@Apfelpom That was in the release notes as a bug fix. Previous versions of the JSS were not logging users out when that was checked. I would guess that it has been checked for quite some time, but due to that bug, no one ever noticed.
I'm actually excited to upgrade due to them fixing this bug in particular.
I'm having some struggles getting our Dev server updated - our servers are still running Server 2008 R2. I'm getting an error from the installer during the "Upgrading web app and starting up Tomcat7 service..." phase that reads "There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor."
@mscottblake: Good to know that the user logout after x feature now works. I looked inside older deliberately zero scoped profiles with Login Window settings and they all have the 30 minutes box checked. Even a new profile in JSS 9.8 with Login Window settings is set per default to log out users after 30 minutes.
Could somebody verify the default state of the box "Log out users after:" before updating to 9.8? Thanks :-)
I can't seem to install the 9.8 JDS on OS X 10.10.5 with Server 5.0.3 already installed. The JDS installer balks at the perceived lack of Server having been launched once and "set up."
@Apfelpom Defaults in new config profile just created in 9.73:
Thanks @Josh.Smith! The defaults are the same in 9.8.
Funny defaults by the way: the automatic login is enable but 30 minutes inactivity later, the user will be logged out. If he failed to remember his login credentials, he will have the choice to take the guest user or to restart ;-)
@mscottblake Me too, this bug was really annoying. Do you know if this is still not a forced logout, i.e. will fail if apps need attention?
The move of the binary is a gotcha for me. I have to update a few scripts that call the binary. We are in the cloud so we are being updated Saturday.
Unable to do remote enrollments via Recon in 9.8, though quickadd packages work fine.
I get:
A connection error occurred: jamf binary failed to install
When I try.
I am able to enroll folks using an earlier version of Recon (9.72), but the jamf binary is busted, when I try to do anything with it I get:
$ sudo jamf policy
Password:
/usr/local/bin/jamf: line 1: syntax error near unexpected token `<'
/usr/local/bin/jamf: line 1: `<html><head><title>Apache Tomcat/7.0.62 -
Error report</title><style><!--H1
{font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;f
ont-size:22px;} H2
ont-size:16px;} H3
ont-size:14px;} BODY
{font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;}
B
{font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
P
{font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size
:12px;}A {color : black;}A.name {color : black;}HR {color :
#525D76;}--></style> </head><body><h1>HTTP Status 404 - /jamf</h1><HR
size="1" noshade="noshade"><p><b>type</b> Status
report</p><p><b>message</b> <u>/jamf</u></p><p><b>description</b> <u>The
requested resource is not available.</u></p><HR size="1"
noshade="noshade"><h3>Apache Tomcat/7.0.62</h3></body></html>'
I can repair this by running a quickadd package.
JAMF support was able to recreate the issue in house while I was on the phone with them and are investigating it now. Any one else seen it?
@hkabik - Just a shot in the dark based on my own issues with the binary move, Have you done a sudo jam manage and a sudo jam enroll -prompt on the machine you are running Recon on. I get the feeling the binary is in the old place on your machine so Recon 9.8 can't call it properly.
That was my gut instinct as well, but it fails to place the binary in /usr/sbin and although it creates the folder for /usr/local/jamf/bin it doesn't actually drop the binary there either.
Does the JSS auto force quit apps before logging off automatically? I think this might be the reason it's not working for me
@ Abdiaziz
I've got the same issue. Nothing big, but I am certainly being warned about scripts and EAs that simply have /usr/sbin in them. I really do appreciate the warnings from the JSS, but after removing any references I had to usr/sbin/jamf. Either way, it was a rather smooth upgrade for us!
In case anyone is interested/experience my enrollment issue.
Just got off a call with JAMF, while the 9.8 (failed jam binary install) and 9.72 (failed jamf plist install/apache error) recon tools fail... the 9.73 Recon app works. So I at least have a work around for right now.
JAMF is able to reproduce my issue so they're running it up the flagpole.
Just wanted to let anyone who experiences this issue know, use the 9.73 Recon app to enroll machines.
@hkabik Thanks for that!
Oh yeah. it doesn't drop the binary at all.
It does make the folder structure for /usr/local/jamf/bin oddly though.
We checked both in that folder and in /usr/sbin. No binary at all.
The worst part is... no binary means no logs. We can't see where it's failing at. No /var/log/jamf.log on the machine being reconnend and without the binary no log gets reported to the JSS.
Mysterious error is annoying.
@Volker I was setting up a new JSS/JDS with Server 5.0.3 and found the same issue.
After extracting the contents of the JDS installer and moving files into place manually, I also ran both pre and post install scripts manually.
Finally, I followed this post https://jamfnation.jamfsoftware.com/discussion.html?id=11841 and used the script locally to finish the setup of the JDS and get it into the JSS. I did need to update the paths for the jds binary check since its in a new location with 9.8
Kind of a pain, but I imaging 9.8.1 will include support for the new OS X Server.app
Hi guys,
Adding onto this post with a strange issue I just encountered. I upgraded to 9.8 (and open jdk 8) in my test environment and they no longer can run jamf commands from ARD. Commands run from remote desktop return "/bin/bash: line 1: jamf: command not found"
If I SSH in, they work fine locally on the machine. I re-added the computers in ARD, but still nothing. Anyone else see this?
@skoonin You're not the only one!
thanks for confirming that I'm not alone in this. such strange behavior! seems there's a variable somewhere not updated?
