Yep, create a policy and enable Self Service option. Here's what we've got set up..
HTH
Don
external image link
external image link
external image link
external image link
Just one small item to add to Don's excellent info and screenshots. Under Scope, you may want to consider creating a Smart Computer Group for any Macs with available updates, or a group that contains more than X number of updates, whatever threshold you feel is important. Doing that will ensure that only Macs that have some updates available will have this SS item show up for them. Otherwise, you may have users clicking on it when there isn't anything to install.
Don is likely already doing something like this, but since he didn't provide a screenshot of his Scope tab, I thought it important to mention.
@mm2270 Ya know, I hadn't thought of that. I just updated our policy to include the scope. :)
@rmaldonado - Throwing my experiences to the mix, I went with the Self Service option when I started using JSS. Only problem is a human one, my folks didn't want to go and install... And just when I thought that hope was lost, I found a script in this thread: https://jamfnation.jamfsoftware.com/discussion.html?id=5404
This script will look for updates, if updates are needed it checks to see if they need a restart, if they don't need a restart then they install automatically, if they do need a restart then it checks if a user is logged in, if no one is logged in then it installs the update and restarts, if someone is logged in then a popup message appears asking if they would like to install updates and restart, if they say yes then it proceeds to install and restart, if they say no then the whole thing closes and it will try again tomorrow.
This process works with two policies:
Part 1: Runs every 15 minutes, once a day. Scoped to a smart group for Macs that need updates. Runs the script I've titled softwareupdate_jamf_helper.sh. Set to update inventory when done.
Part 2: Is only triggered by the manual trigger "runsoftwareupdate", ongoing frequency. Scoped to all computers. In the Packages tab the Set Server and Install All Software Updates buttons are checked.
This has worked flawlessly since I've used it. I hope that one day this gets integrated into the Casper Suite itself. Here's the version of the script that I use:
#!/usr/bin/perl -w
use strict;
my $AVAILABLEUPDATES="";
$AVAILABLEUPDATES=/usr/sbin/softwareupdate --list
chomp $AVAILABLEUPDATES;
printf "available updates is %s
", "$AVAILABLEUPDATES";
# If available updates contains * there are updates available
if ($AVAILABLEUPDATES=~/*/){
printf "there are updates available
if ($AVAILABLEUPDATES=~/(restart)|(shutsdown)/){
printf "updates need a restart
my $LOGGEDINUSER='';
$LOGGEDINUSER=/usr/bin/who | /usr/bin/grep console | /usr/bin/cut -d " " -f 1
chomp $LOGGEDINUSER;
printf "value of logged in user is $LOGGEDINUSER..
if ($LOGGEDINUSER=~/[a-zA-Z]/) {
printf "as there is a logged in user checking whether ok to restart
my $RESPONSE = "";
$RESPONSE=system ''/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper' -startlaunchd -windowType utility -icon '/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/Resources/Message.png' -heading "Software Updates are available" -description "Your computer will need to restart in a few minutes, would you like to install the updates now? Please wait for the next message before restarting. You can run updates at anytime by using Self Service in your Applications Folder." -button1 "Yes" -button2 "Cancel" -cancelButton "2"';
if ($RESPONSE eq "0") {
printf "
User said YES to Updates
system "/usr/sbin/jamf policy -trigger runsoftwareupdate";
exit 0;
} else {
printf "
User said NO to Updates
exit 0;
else {
printf "no logged in user so ok to run updates
exit 0;
else {
printf "no restart required
exit 0;
else {
printf "there are no updates available
exit 0;
exit 0;
@UESC does the MAS open on 10.8.x machines when you do it that way or does it do it silently?
@jwojda - Silently. Unless the update needs a restart, then the popup appears to give the user the choice. No MAS involved at all.
Thanks everybody for all the helpful responses. I will be giving all these suggestions a try in our test bed and figure out which one will be perfect for us. I'll keep you guys updated!
Is the 'All Managed Clients' group part of the Scope as you show in your screenshot? If so, that's going to lump all your managed Macs into the scope for the SS policy, which would explain why Macs that already have Firefox installed are showing up. You want to scope it only to the Smart Group looking for Macs without Firefox installed. Smart Groups can only contain managed Macs, so there's no need to add the All Managed Clients in there.
Yeah, I realized that right when I made that last post. Thank you for that! I was hoping nobody would see it before I could edit that post to explain, but you were too fast. Just had a tired moment. Been staring at JAMF too long today :P
Heh, I had a feeling that was why your post disappeared. No worries. Had I seen it was gone I wouldn't have posted. Just crossed paths in the interwebs I guess :)
Alright guys, my software management is rocking now. Thanks to everyone for their input, I picked and pulled from everyone and found the perfect solution for my environment. If I could bother with ONE last question, I promise I'll leave you guys alone(for now)! All I want to do is have my SS policies run Recon at the end, so that the change in what they see in SS is instantaneous(to them anyway). Does anyone know how to do that? or is it a script that needs to be run?
@rmaldonado - Glad you found what you're looking for! :)
Check the Update Inventory button in the Advanced section of the policy.
@UESC this script is a lifesaver. I have got updates working perfectly.
On a related note, I work in a place where security is extremely important, and I was approached today about the icon that pops up in the update window that this script uses(message.png) and was told that it might be construed as malicious since it looks so generic
I know that the /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/Resources/ is installed to every machine as soon as it joins via casper, but I am having trouble locating where that content comes from. My end result is uploading my own icon, and then modifying the script to call my custom icon instead
thanks guys, collectively you have all helped me stand up a custom update model for my environment.
So glad the script is helping others :)
You can customise the icon here:
If you change it here too, if you have the login/logout status showing, this will also show your customised icon.
thank you @lisecherie. The script is awesome, and solved all of our issues with Apple software updates through casper. I now have it working 100% with our personal icon
Strange question regarding the icon (message.png). What is your most successful method for modifying that file. jamfHelper.app gets installed during the recon process (or imaging). I'm assuming that there's an easier way to distribute the modified jamfHelper without breaking anything.
P.S. This script is fantastic! Thank you so very much!
The file 'message.png' as well as several other equally customizable items are located within your actual netboot set--in our case this location is the secondary HD of our Mac Mini providing netboot services.
SO: /Library/NetBoot/NetBootSP0/YourNetBootSet.nbi/NetBoot.dmg
mount the .dmg within the mounted .dmg
navigate to /Applications/
Right click on 'Casper Imaging.app'
Show Package Contents
Navigate into /Contents/Resources
You can now see the various files that your netboot set plants on the clients. replacing any of these .icns or .pngs with your customized files (but remembering to name them identical to the ones you are replacing) will give you the desired results.
That's how we do it here, but I hope that helps!
Each time the jamf binary is updated/reinstalled it replaces the png file.
Its kind of low priority for me as it is cosmetic, so I have a policy that I flush every now and again to replace the file after doing casper upgrades. If you wanted to be clever put in an extension attribute to compare something on the png file, and then scope to smart group.
@lisacherie is correct in that it will replace your custom icon when the JSS come out with an update. You would just have to replace the default icons with your custom ones at time of upgrade. I have full access to everything so the overhead is minutes for me to replace the default icon. I guess it depends on how much access you have :P
Thanks for the info! This really is one of the very best user forums I've ever had the privilege of subscribing to. Now to see what I can't go break. ;-)
This script works awesome. Would there be a way to modify it so downloads are updated in the background prior to the message displaying for logged in users? Testing this as a logged in user, I click okay to install updates and then it downloads and installs and then I'm greeted again by the Casper dialog to restart the machine. Over our crappy wireless, this can take some time, esp for big updates. It would be nice if the updates were downloaded and installed in the background with the restart occurring as soon as they click okay.
You could modify the script you chose to add the following if the user selects no:
softwareupdate --download
If you don't have internal SUS, consider setting one up, the downloads are very fast here from internal SUS. If you do have internal SUS check for this problem, which might be sending you to Apple, and making your updates download slowly....
https://jamfnation.jamfsoftware.com/discussion.html?id=6671
I am trying to implement the script posted above on Sierra. It fails with the following:
Running script softwareupdate_jamf_helper.sh...
Script exit code: 255
Script result: Bareword found where operator expected at /Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh line 7, near "--list"
(Missing operator before list?)
Unknown regexp modifier "/b" at /Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh line 7, at end of line
Unknown regexp modifier "/n" at /Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh line 7, at end of line
syntax error at /Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh line 7, near "--list"
syntax error at /Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh line 14, near "if"
Unknown regexp modifier "/b" at /Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh line 24, at end of line
Unknown regexp modifier "/n" at /Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh line 24, at end of line
/Library/Application Support/JAMF/tmp/softwareupdate_jamf_helper.sh has too many errors.
Error running script: return code was 255.
Is the script as written not compatible with Sierra?
