I have a support ticket open on some items that are DB related, however I've come across what I think are some bugs in the configuration/classes in the manual installation. Has anyone successfully used this in their environment?
The issues I'm having are that the class files seem to hard-code some file paths that you are supposed to override with configuration files. For instance, the java ssl keystore file and the JSSChangeManagement.log file.
I have brought these up to support, I'm thinking they are a bug, but I was wondering if anyone else has had this issue.
