scripting...
  • May 22, 2009
  • 0 replies
  • 10 views
Hi, I'm trying to get my script (which works locally) to deploy over Casper
and it's not. I'm trying to determine whether there are certain
directories present and, if there are, run a command to install an item
into the dock. I have used the built-in parameter substitution and I've
tried it without. In most cases, the script appears to run but does
nothing. This is a sample of the variations I've tried thus far.
# Application variables
computerName=$2
someapp1=$2/Applications/Something I Need To Deploy
someapp2="$2/Applications/Something"
someapp3="$computerName/Applications/Something"
Here is the actual script.
# Applications
kid_pix="/Applications/Kid Pix Deluxe 4"
ttl="/Applications/Type To Learn 3"
kidspiration="/Applications/Kidspiration 2" inspiration="/Applications/Inspiration 8"
if [ -e $kid_pix ]; then
defaults write com.apple.dock persistent-apps -array-add
"<dict><key>tile-data</key><dict><key>file-data</key><dict><key>_CFURLString</key><string>/Applications/Kid
Pix Deluxe 4/Kid Pix Deluxe
4/</string><key>_CFURLStringType</key><integer>0</integer></dict></dict></dict>"
if [ -e $kidspiration ]; then
"<dict><key>tile-data</key><dict><key>file-data</key><dict><key>_CFURLString</key><string>/Applications/Kidspiration
2/Kidspiration
2.app/</string><key>_CFURLStringType</key><integer>0</integer></dict></dict></dict>"
if [ -e $inspiration ]; then
"<dict><key>tile-data</key><dict><key>file-data</key><dict><key>_CFURLString</key><string>/Applications/Inspiration
8/Inspiration
8.app/</string><key>_CFURLStringType</key><integer>0</integer></dict></dict></dict>"
if [ -e $ttl ]; then
"<dict><key>tile-data</key><dict><key>file-data</key><dict><key>_CFURLString</key><string>/Applications/Type
To Learn 3/Type To Learn
3/</string><key>_CFURLStringType</key><integer>0</integer></dict></dict></dict>"
killall Dock
John McLaughlin
Technical Support Specialist
Newton Public Schools
