Has anyone tried to package up the recently released (2 or 3 days ago) Service Pack 1 for Microsoft Office 2011? I cannot get a working package created using standard Composer methods.
DETAILS
1) Using Casper Suite 8.0
2) Packaging against a clean 10.6.4 OS image with only the initial base MS Office 2011 installed
3) Downloaded Service Pack 1 .dmg from MS website – the .dmg contains an installer
4) Using Composer 8.0 – Normal Snapshot method
WHAT HAPPENS
After running Composer snapshot of pre-install environment, install of Service Pack 1 for MS Office 2011 proceeds normally. Post snapshot package creation runs normally, but when I review the list of difference files created by Composer, I find that each of the MS Office 2011 application files is grayed out in the /Applications folder, with the prohibitory sign over the app icon. The Contents files within the apps appear to be fine. Other difference files in the /Library folder appear fine.
I've never seen this happen before. I've tried applying the /Application folder permissions to everything inside, but no luck.
Thoughts, anyone?
Jeff Elliott
Tech Support Specialist
Hempfield School District
Landisville, PA
