I'm having problems getting auto-mounts to work at login using the mountnetworkshare script. The 10.6 machines fail to mount the share on the first login but all subsequent logins are successful for that account. All of the 10.5 machines are the exact opposite, they work the first time but any attempts after that fail. The /Volumes folder is cleaned out at login/logout to avoid any conflicts.
Any ideas?
Jeremy
