New Macs shipping with Yosemite are corestorage enabled out of the box, and corestorage is enabled on FV2 enabled Macs.
Casper NetInstall Creator 5 (current) has an issue creating an NetBoot Image (NBI) that can "Erase the target drive":
Casper Imaging could not locate any drives for imaging.
external image link
I saw some threads on it, mostly pointing to @bentoms][/url][/url][/url' excellent AutoCasperNBI tool:
https://macmule.com/autocaspernbi/
For business reasons we want/need to first try to get JAMF Software's tools to work, or help push for a fix.
Thought I'd post here to see if any JAMF Nation or JAMF Software folks might have an answer, before opening a ticket.
TIA,
Don
Hit this with my current workflow as well. Fix in the below link works but really expect JAMF to be on the ball with getting their tools supporting these types of changes from Apple.
https://macmule.com/2015/01/02/casper-imaging-corestorage-volumes/
@nixonc85][/url Thanks, I just found the other thread. JAMF might do well to hire @bentoms][/url. :)
https://jamfnation.jamfsoftware.com/discussion.html?id=13260
@donmontalvo, what are the exact steps you're taking to see this error?
Also, have you tried Casper Inaging 9.32?
@bentoms Casper NetInstall Creator 5.0 > NBI > NeBoot a corestorage enabled Mac > error comes up as Casper Imaging launches in its runtime environment.
Doesn't look like 9.64 (released an hour ago; thanks JAMF for putting in hours on a holiday!) fixes the problem. :(
Um....not for nothing, but....
https://github.com/jamf/CasperNetInstallCreator/issues/1
@bentoms I'm going to assume you meant 9.62, we just tried and no go.
Nope I meant 9.32.
But it seems fixed in 9.65.
I thought/hoped so too. Casper NetInstall Creator 5.0, Casper Imaging 9.65, iMac 5K Retina, getting these errors:
optional image ALT text
Delete the Autorun, then try.
Sorry for being a little off topic, but has anyone gotten the NetInstall LaunchPad to work in the latest build of Casper NetInstall Image Creator. I've created the netboot set, netbooted off it and when I quit Casper Imaging I just get a terminal window instead of the LaunchPad.
Just a quick follow up to thank JAMF for 9.7, it resolved the FileVault 2 issue.
Casper Imaging can now deal with FV2 enabled drives (re-image) and core storage enabled (Macs shipping with Yosemite).
Man, I want some of that coffee! :D
Kudos!
Don
We actually had a discussion about this last week. If we quit Casper Imaging while booted into the Casper NetInstall runtime environment, we're left in a wonky state. There doesn't seem to be a menu to get to Terminal, Safari, etc.
TBH not sure if it was there before since we only recently started using Casper NetInstall Creator when v5 was released. Hoping for v5.1 with a fix. We realize it isn't an official product, but its way more than a nice-to-have. :)
Don
