Hello, I'm trying to figure out what criteria to search for to determine which computers were enrolled via DEP and those who register via self-enrollment.
In 10.13, seems pretty straight forward, as there's flags set for this. However, what about the 10.12 computers? I can't seem to figure out a specific app or field to follow. I've tried a couple of the recommendations of what I've found by searching, but they don't appear to do what I want
The use case is this: I have certain policies and config profiles that auto-deploy if you enroll by DEP. This would constitute a "clean" image. However, I do not want certain policies to apply if they are self enrolled, as they may wipe out certain user preferences, or the applications may have already been installed by another method (imaging, etc.).
Try to make a smart with the following settings:
Criteria: Enrolled via DEP
Operator: is
Value: Yes
I think this only works if you are 10.13. It doesn't populate if you are 10.12.
All of my machines appeared in the list after using this only...
I think I may have figured it out.
I have smart groups detecting OS versions. It was just a matter of figuring out what gets set on a user enrolled computer vs not. Are there any other use cases for com.jamfsoftware.osxenrollment that get called for a DEP enrollment?
Slight error in the screen shot. It should be does not have com.jamfsoftware.osxenrollment
doh, this only works up until the popup to allow Jamf to manage your computer appears and the user clicks yes.
Then the installer app deploys the necessary enrollment package and my check fails.
10.13 detection works fine.
any other ideas?
@jbellez I'm trying to work up something very similar to you. Did you ever come up with a solution? I've tried working with "Enrollment Method: Assigned to prestage" is not/not like [my prestage name A] or [my prestage name B] but have not had any luck or get results that I know are incorrect.
Tim
Well, here's an idea: if you are using prestage enrollment profiles, would that be enough to signify a Mac was enrolled via DEP? If you create a smart group of computers that ARE assigned to one more more prestages, then create another smart group of computers that ARE NOT a member of the former group, would that only leave your machines that were self enrolled? Or do you have other scenarios like imaged machines to take into account?
@timlarsen You can't use assigned to prestage, as a machine can be assigned to a prestage, but also be provisioned before DEP was enabled. Upon next reformat, it will use DEP to enroll, but that doesn't mean it was DEP enrolled to begin with. It may also be the case that the machine doesn't even have Jamf installed at this point, as the machine will just sit in the prestage waiting to check in and enroll itself.
Also, no, we never found a way to do what we wanted this way. We ended up scoping it differently.
