Hi all,
I'm getting my feet wet with Casper suite with a Mac standardization project in a large corporation. I've been using ARD to manage about 500 Macs across the USA, Europe and Asia and am now graduating to the Casper Suite with a master JSS, and about 10 distribution servers. We are starting a project to reimage all the Macs to a corporate standard build, tied into AD (using Centrify), and managed mostly by myself (California) and another tech (Florida) with a little help from the local PC techs. The sites have anywhere from 100 Macs down to 2-3.
Now that you know a little about my set up, I have a few specific questions, and also just want to run a sanity check to solicit tips and suggestions and maybe a horror story or two to try to avoid some pitfalls. We are on a tight time constraint on this project, so little delays that can be avoided would help a lot.
The larger sites have a server, but not all sites. I do have some G4's sitting on a shelf I can ship out to serve as a distribution point locally (versus the WAN) for no cost other than the shipping charge.
We want to give the departments the option of running CS3 or CS4 (design standard) and I was thinking Self Service would be the best way - as it would allow them to switch over as a team when they decided was best for them.
Some sites are small and have no on-site technician. I was thinking of creating an emergency boot partition. I saw an option to hide a partition in Casper. Haven't tried it yet - has anyone used this type of thing to enable a remote reimage?
I think I have most of the printer drivers installed into the master image. I plan to have a local tech map one machine to all the printers and use Casper Admin to capture the printers and make a rule to add those printers to that site, or select them during the Casper imaging run. Is there a way to make the printers show up in Self Service? I gave it a shot the other day, but it didn't work.
In JSS setup, if you schedule a replication, it should start immediately, then follow the schedule, correct? If I click "remove Schedule" will that stop a rsync that is in progress? Or does it go until completion? If I copied an image to a local server in the CasperShare/Images directory, will the sync replace that with the one from the JSS master server at the next replication? That isn't a bad thing - but trying to work around having our master server in a data center 3 time zones away and making updates to our master desktop image (6GB) that I have to copy over the WAN for 1/2 a day, then replicate back locally over another 1/2 day before I can start imaging systems.
Sorry for the flood of info and thoughts - but I do appreciate any insights/tips/gotchas/resources you are willing to share.
Rich Barron
I will try to respond as best as possible....Been using Casper for 2 years at a school in a 1:1 program of 6,000+ macbooks and about 30 Xserves
I will try to answer your questions below under the paragraph
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
blackberry: 913-449-7589
office: 913-627-0351
