We are getting ready for a domain migration of our Active Directory. I've built a policy that uses the unbindAD script from the Resource Kit and then binds the machine to the new domain. The policy is set up as a self service for our techs only.
The issue I am having is that after the un/rebind there are duplicate entries for Active Directory/All Domains in the Search Policy section of the Directory Utility. They appear under both the Authentication and Contacts tabs.
My thought is to create another script that will run before the rebind to reset the search policy settings to factory (only /Local/Default and /BSD/local). Can anyone point me towards the appropriate terminal command or have any thoughts on this?
Thanks for any help,
Tom
Tom Tubbiola
Design IT
Ttubbiola at oakley.com
949.900.7705
