HTTP(S) Downloads from OS X Server Distribution Point, 403 Forbidden
  • February 15, 2015
  • 13 views
I know this has to do with a permissions issue on OS X server, but where and how do set permissions (Server App). I think it may have something to do with _www user having Read rights, but cannot Add this user and set permissions in Server App 4.
I do have the CasperShare sym link created in: /Library/Server/Web/Data/Sites/Default/
This is pointing to a separate volume / share on OS X server. Thx in advance
  • 159 replies
  • February 15, 2015
Instead of Symlink, try creating an Alias. Also, by default Yosemite server will auto redirect HTTP to HTTPS, so be sure to either get a 3rd party certificate or disable the redirect.
external image link
  • 5 replies
  • June 22, 2016
Edit: removed, found answer online.
  • 22 replies
  • September 1, 2016
@tim.arnold Would you mind sharing what you found? We're running in to a similar issue.
