'About This Mac' shows number instead of OS X name
  • February 17, 2015
  • 4 replies
  • 66 views
I ran across a weird issue where the About This Mac info box shows a number instead of "OS X Yosemite".
external image link
It's not related to the image since I imaged two Macs simultaneously (same AutoDMG image through DeployStudio) and only one of the computers have this issue. This doesn't seem to affect performance, it's just weird.
I've tried repairing disk permissions which had no effect. Does anyone know how to fix this? I'd like to avoid re-installing the machine since it's such a "small" issue.
Best answer by stevevalle
I have read somewhere that it is a language selection issue. Choose English (Australia) and the number should change. I haven't had this issue, so I can't test it!
  • February 17, 2015
Seeing the same. Exact same number.
davidacland
  • February 17, 2015
Just had a look for the string "OS X Yosemite". I can't find it in sw_vers or system_profiler anywhere so I'm not sure where its pulling it from.
Hopefully its just a cosmetic issue and won't cause problems with a script further down the line!
  • February 18, 2015
  • February 18, 2015
stevevalle success!
Changing the language and removing the "faulty" one seemed to work (reboot required!) . I chose English (U.K) since that's where I'm shipping the device (my DeployStudio workflow just chooses "English" which I guess is English International of something). Anyways, thanks for your help guys!
