Does anyone have any idea how to package spectraview II for the enterprise. My issue is that it requires a license key, but there doesn't seem to be any file or key that gets created when the software becomes licensed. The installer is just a .pkg from te manufacturer.
I also tried a build and capture using the new and modified setting in composer to no avail.
It holds the license key somewhere, because when I install the software and license it, then remove the software and reinstall it, it does not ask for the license key again.
I've deleted all app support folders and pref files and it still didn't ask for the key.
