When restoring the Recovery HD, how do I hide it again?
  • May 10, 2012
  • 40 views
I have successfully restored the Lion Recovery HD to an additional partition with Casper Imaging, and I can boot from it, but it's no longer hidden like an out-of-the-box OS X Lion instance. Is there an obvious way to hide it?
Best answer by daworley
Check out the diskutil and asr lines at the bottom of this article: https://jamfnation.jamfsoftware.com/article.html?id=173
  • May 10, 2012
  • May 10, 2012
Thanks! I've read that article a bunch of times. Thanks for the reminder, Doug.
In my case, I have the 10.7.4 installer, then the Recovery HD, then a Winclone volume. And somehow I now have 2 Recovery HDs (/dev/disk0s3 and /dev/disk0s4). Back to Casper Admin!
  • May 10, 2012
I have found that running the config described in the article above a few times does funny things with creating multiple recovery partitions.
I took to using Disk Utility's debug menu and enabling the "Show Every Partition" feature. That let me know that when I wiped the disk, it was actually cleaning out any previous hidden partitions.
Otherwise, I bet some savvy diskutil scripting could discover those partitions and mount them for re-restoration.
