Allow non admins to change Network preferences.
  • December 6, 2011
  • 7 replies
  • 62 views
I have a script that has been working for 10.6 that unlocks Network for non admins, but it doesn't seem to work with 10.7. Anyone have any ideas what it takes to make it work in 10.7? Below is my current script I am using for this.
Alan
#!/usr/bin/perl
$plbud = "/usr/libexec/PlistBuddy";
$auth = "/private/etc/authorization";
$sysprefso = `$plbud -c "print :rights:system.preferences:session-owner" $auth`;
if ($sysprefso !~ /true/) {
print"Needs authorization file modified
# Set system.preferences settings here
system"$plbud -c "add :rights:system.preferences:session-owner bool true" $auth";
system"$plbud -c "set :rights:system.preferences:session-owner true" $auth";
system"$plbud -c "set :rights:system.preferences:allow-root true" $auth";
system"$plbud -c "set :rights:system.preferences:comment Authenticate either as the owner or as an administrator." $auth";
print"Modified authorization file to allow non-admins to modify network settings
else {
print"authorization file already modified
Best answer by mattsmacblog
10.7's authorization file has much more granular control.
The keys that need changing in /etc/authorization are
<key>system.preferences</key>
<key>system.preferences.network</key>
Your script probably still works for the top key, but you'll need to extend it to unlock the second.
I wrote some info up here - http://mattsmacblog.wordpress.com/
It's not at the scripting level and I haven't gone into <key> vs <group> based unlocking. You can change <key>system.preferences.network</key> from the <user> class to <rule> to apply the session-owner rule if you want.
Matt
  • December 6, 2011
Matt
  • December 6, 2011
Thanks! Here is what I came up with for editing my authorization file.
I add the .plist to the file when copying because I have a couple of defaults write commands that run on the file as well.
#Copy file to tmp location
/bin/cp -pr /etc/authorization /private/tmp/authorization.plist
# Unlock System Preferences for non admins.
/usr/libexec/PlistBuddy -c 'Set :rights:system.preferences:group staff' /private/tmp/authorization.plist
# Unlock Network Settings preference pane
/usr/libexec/PlistBuddy -c 'Set :rights:system.preferences.network:group staff' /private/tmp/authorization.plist
# Unlock Printer Preference pane
/usr/libexec/PlistBuddy -c 'Set :rights:system.preferences.printing:group staff' /private/tmp/authorization.plist
# Unlock time machine preference pane
/usr/libexec/PlistBuddy -c 'Set :rights:system.preferences.timemachine:group staff' /private/tmp/authorization.plist
# Unlock energy saver preference pane
/usr/libexec/PlistBuddy -c 'Set :rights:system.preferences.energysaver:group staff' /private/tmp/authorization.plist
# Move file back to original location
/bin/mv /private/tmp/authorization.plist /etc/authorization
  • March 22, 2012
Thanks for this!
  • September 11, 2012
Imm newbie can you tell me where to put this script to get it to work.
Thank you
Forum|alt.badge.img+20
Login script would work.
  • October 18, 2012
Will this still work in 10.8 or has the authorization file changed?
  • October 18, 2012
It's pretty much the same, although i found that for unlocking network prefs in ML you have to modify the
system.services.systemconfiguration.network
in addition to what's mentioned above.
E.g.
/usr/libexec/PlistBuddy -c 'Set :rights:system.services.systemconfiguration.network:rule allow' /etc/authorization
