How to display IMEI info?
  • May 14, 2014
  • 38 views
I can see where to search for it in an Advanced Search, but how do I just display that info? Didn't see a choice in Inventory Display. I'm running 9.3.
Brian
Best answer by lashomb
Nevermind this... I just decided to look in the database. If anyone finds this (and I've seen a few posts like this with no responses), just do this.
And yes I know... bad things to run mysql as root, but here it is anyway...
On your JSS, navigate to the mysql/bin directory and run:
./mysql -u root -p.
In my JumpStart, the root password was left blank. In this case simply hit return to get to a mysql prompt.
Next we’ll need to tell mysql which database we want to use. Type this and hit return:
USE jamfsoftware;
Running from the mysql prompt shows the fields we can select:
SHOW COLUMNS FROM mobile_devices_denormalized FROM jamfsoftware;
You'll see a list of all fields.... I'm just using username and imei in this example.
Run from the mysql prompt:
SELECT md.username, md.imei FROM mobile_devices_denormalized AS md INTO OUTFILE '/Users/Shared/mobile.txt';
Now you have that data in a text file in the directory you specified.
  • May 14, 2014
./mysql -u root -p.
USE jamfsoftware;
bentoms
Forum|alt.badge.img+35
  • May 14, 2014
@lashomb, you should also be able to do this via the API.
JAMF are advising against DB queries as they may change the tables, but the API should remain.
  • May 14, 2014
Thanks Ben.
