How do you Put a Computer into a Static Group with API>
  • November 8, 2018
  • 20 replies
  • 226 views
Hugonaut
Forum|alt.badge.img+15
So I came across this article https://www.jamf.com/jamf-nation/third-party-products/files/658/jssid-list-to-static-group-using-the-api-script But I was wondering if I can pass along a curl command in a single line with a computers ID to a static group using the Statics Group ID instead of writing out to a tmp xml file. Here is an example of a basic script I'm using to test. For the moment, I'm using a test serial number since I can easily populate my serial numbers into the script.
If this is possible with a simple (rough example to get the point across)
put $JAMF_COMPUTERID to "${apiuser}:${apipass}" "${jssURL}/JSSResource/computergroups/id/${GROUP_ID}"
that would be awesome
# Variables - Do Not Modify
# API Credentials
apiuser="api"
apipass="pass"
jssURL="https://jamf.server.com:8443"
# Serial Number
JAMF_SERIAL="###########"
# Pull Computer Asset Tag  from JAMF
JAMF_STUDENTID=$(curl -H "Accept: text/xml" -sfku "${apiuser}:${apipass}" "${jssURL}/JSSResource/computers/serialnumber/${JAMF_SERIAL}/subset/general" | xmllint --format - 2>/dev/null | awk -F'>|<' '/<asset_tag>/{print $3; exit}')
echo $JAMF_STUDENTID
# Pull Computer ID from JAMF
JAMF_COMPUTERID=$(curl -H "Accept: text/xml" -sfku "${apiuser}:${apipass}" "${jssURL}/JSSResource/computers/serialnumber/${JAMF_SERIAL}/subset/general" | xmllint --format - 2>/dev/null | awk -F'>|<' '/<id>/{print $3; exit}')
echo $JAMF_COMPUTERID
# Put Computer ID into JAMF Static Group
GROUP_ID="##"
??? put $JAMF_COMPUTERID to "${apiuser}:${apipass}" "${jssURL}/JSSResource/computergroups/id/${GROUP_ID}"
Best answer by boberito
Here's how I've updated group membership in the past
It's a bit more than you had.
#API login info
apiuser="USERNAME"
apipass='PASSWORD'
jamfProURL="https://jamfproserver:8443"
ComputerName=$(hostname)
#update group with ID 232 aka group you want
GroupID="1234"
apiURL="JSSResource/computergroups/id/${GroupID}"
#XML header stuff
xmlHeader="<?xml version="1.0" encoding="UTF-8" standalone="no"?>"
apiData="<computer_group><id>${GroupID}</id><name>Whatever the GroupName Is</name><computer_additions><computer><name>$ComputerName</name></computer></computer_additions></computer_group>"
curl -sSkiu ${apiuser}:${apipass} "${jamfProURL}/${apiURL}"
    -H "Content-Type: text/xml"
    -d "${xmlHeader}${apiData}"
    -X PUT  > /dev/null
boberito
Forum|alt.badge.img+22
  • November 8, 2018
#API login info
apiuser="USERNAME"
apipass='PASSWORD'
GroupID="1234"
#XML header stuff
    -X PUT  > /dev/null
Hugonaut
  • November 8, 2018
@boberito
SOLID! Thank you! This was driving me crazy, huge help man.
  • August 12, 2019
@boberito
You ever done this process for Mobile Devices. Tried to adapt your method but having no luck.
  • August 12, 2019
Got this working.
<mobile_device_group><id>${GroupID}</id><name>GROUP NAME</name><mobile_device_additions><mobile_device><serial_number>SERIAL NUMBER</serial_number></mobile_device></mobile_device_additions></mobile_device_group>"
  • October 18, 2019
@boberito
Nice script but I seem to have to adde the ComputerName to the APIData call, if I put the computerName as below nothing happens
ComputerName=$C024567GH
sdagley
  • October 18, 2019
@MatG In a bash script the $ means get the value of the variable following the $, so what you wrote is trying to assign the value of a variable named C024567GH to the variable ComputerName. Since you're trying to assign the serial number C024567GH to ComputerName what you want to write is ComputerName="C024567GH".
L3nny5
  • February 7, 2020
Can anybody tell me, what the minimal needed API account rights are, for this to work?
beeboo
  • March 30, 2020
@L3nny5 needs admin to PUT/POST
  • May 18, 2020
Regarding API User privileges, I used Access Level: Full, Privilege Set: Custom (which starts with NO privileges), then added Jamf Pro Server Objects> API Integrations (C-R-U-D as needed) and Static Computer Groups (C-R-U-D as needed)
  • May 18, 2020
Confirmed with my Jamf Buddy: ":8443" is not needed for Jamf Cloud.
  • June 3, 2021
@adamnewman I'm trying to do this with mobile devices as well but I'm having issues with using this with Basic Authorization and getting "Object must be specified as an xml file". Any thoughts?
Heyo, really need to get this working for a workflow. I keep getting error code 127 (command not found) and I'm not sure why...
Looks like it's erroring out in lines 22-23 of the last curl command:
curl -sSkiu ${apiuser}:${apipass} "${jamfProURL}/${apiURL}" -H "Content-Type: text/xml" -d "${xmlHeader}${apiData}" -X PUT > /dev/null
This is the error I get in Terminal when I call the policy via -trigger:
<?xml version="1.0" encoding="UTF-8"?><computer_group><id>123</id><name>The Group Name I specify</name><is_smart>false</is_smart><site><id>-1</id><name>None</name></site><criteria><size>0</size></criteria><computers><size>0</size></computers></computer_group>/Library/Application Support/JAMF/tmp/Add Mac to Static Group: line 21: -H: command not found /Library/Application Support/JAMF/tmp/Add Mac to Static Group: line 22: -d: command not found /Library/Application Support/JAMF/tmp/Add Mac to Static Group: line 23: -X: command not found Error running script: return code was 127.
Any ideas?
sdagley
  • January 18, 2022
Any ideas?
@user-dzIJnCprEb The curl command should all be on one line, or you need to use the \\ line continuation indicator if you're breaking it across multiple lines, e.g:
curl -sSkiu ${apiuser}:${apipass} "${jamfProURL}/${apiURL}" \\ -H "Content-Type: text/xml" \\ -d "${xmlHeader}${apiData}" \\ -X PUT > /dev/null
Gah, ok fixed that. So now the policy completes, but the machine is not added to the group.
If I run the script locally in verbose, I get the following, but again Mac is not added to the group:
Last login: Tue Jan 18 13:49:09 on ttys000 admin@admin's-Mac ~ % sh -x /Users/admin/Desktop/group_add.sh + apiuser=[jamf_user] + apipass=[password] + jamfProURL=https://[my org].jamfcloud.com ++ /usr/sbin/scutil --get ComputerName + ComputerName='Admin'\\''s Mac' + GroupID=131 + GroupName='Test Group' + apiURL=JSSResource/computergroups/id/131 + xmlHeader='<?xml version=1.0 encoding=UTF-8?>' + apiData='<computer_group><id>131</id><name>Test Group</name><computer_additions><computer><name>Admin'\\''s Mac</name></computer></computer_additions></computer_group>' + curl -sSkiu [jaf user]:[password] https://[myorg].jamfcloud.com/JSSResource/computergroups/id/131 -H 'Content-Type: text/xml' -d '<?xml version=1.0 encoding=UTF-8?><computer_group><id>131</id><name>Test Group</name><computer_additions><computer><name>Admin'\\''s Mac</name></computer></computer_additions></computer_group>' -X PUT admin@admin's-Mac ~ %
 What am I missing?
sdagley
  • January 19, 2022
 What am I missing?
@user-dzIJnCprEb Looking at the verbose output it appears you are escaping characters in your computer_name field incorrectly. The escape character is a \\, not a '. Using computer_name is also problematic as there's no guarantee that name will be unique. Using serial_number would be safer (although surprisingly not guaranteed to be unique) so the apiData would look something like this:
<computer_group><id>${GroupToAddToID}</id><name>${GroupToAddToName}</name><computer_additions><computer><serial_number>${ComputerSerial}</serial_number></computer></computer_additions></computer_group>"
GGInquisitor
  • March 17, 2022
 What am I missing?
Did you ever figure this out?  We are seeing the same thing.  The command completes but we get bad request in the return.
  • June 23, 2022
#API login info
apiuser="USERNAME"
apipass='PASSWORD'
GroupID="1234"
#XML header stuff
    -X PUT  > /dev/null
how to use this in postman?
dlondon
  • June 28, 2022
You could try the final script shown here https://community.jamf.com/t5/jamf-pro/bearer-token-api-and-adding-computer-to-static-group/td-p/261269
It's based on things several people above have said as well as Richard Trouton and uses the new Bearer Authentication Token that you should be moving to before Jamf shuts down the Basic Auth
  • October 31, 2022
Will this work for multiple serial numbers?
something like
<serial_number>${ xxxxxxxx, xxxxxxxx, xxxxxxx}</serial_number>
  • October 31, 2022
I mean
ComputerSerial=$( xxxxx, xxxxx, xxxx )
