I'm having a ton of problems with our new deployment of Casper 6 to about
15 servers. Things are not replicating, Adobe installs don't get listed in
Casper Admin, Self Service is super flakey, reimaging is skipping the main
disk image, etc.
I have a feeling it has something to do with the initial setup/config, and
possibly not using fully qualified domain names. It could also have
something to do with permissions or accounts on the server side or client
side. But there is just too much going wrong for this to be considered
normal.
Support has been great. I should know - I have called them every day. 🙂
But short of getting a Casper rep out here to go over the whole system and
find/fix all the bugs, is there a good listing of where all the config
files are stored and what they should look like? On both the client side
and server side? Or maybe someone wrote a doc on what happens in the
background when you, say, schedule a replication from the master server to
another server so when it fails, I can check all the steps manually, such
as making a connection via SSH with the casperadmin name/pass from the
master server to one of the other servers, and where to apply a fix should
a problem be found?
Rich Barron
Is this a new installation or are you expanding an existing infrastructure? If it's new, I'd say back up any packages that you've made and start over. Even if you seem to route out all of your problems, I'd be weary about feeling confident in the installation - if it were me anyway...
The general gist of your situation tells me dns, dns, dns. Related, you should always use FQDNs.
j
This is a new install. When we had our jumpstart, we had just set up 4
servers in a data center about a month ago by a JAMF rep. The other dozen
or so distribution point servers were pre-existing and were not set up
until later by myself.
Now that we are in production and I have a team of guys doing reimages,
where are the files I need to check to ensure the servers have FQDN's in
the settings? I worked with JAMF to write the FQDN of our master server to
the /private/etc/jamf.conf to ensure any tech who does not enter the fully
qualified domain name of the master server during reimaging will not cause
a major problem.
So - where are some other file locations to check - maybe something on the
server? Is there any documentation on this? If this is such a critical
issue, would it not make sense to put a preference file somewhere and have
an easy to manage setting in the GUI for this to be updated after the fact
if needed?
Are there any guides anywhere to what all is involved in 'starting over'?
Is it a simple remove from the master servers and reinstall? Or do things
need to be updated on the clients as well to ensure they are all synched
up properly to the new set up?
Rich Barron
"Nichols, Jared" <jared.nichols at ll.mit.edu>
06/30/2009 05:16 AM
To
"Rich_Barron at vfc.com" <Rich_Barron at vfc.com>,
"casper at list.jamfsoftware.com" <casper at list.jamfsoftware.com>
cc
Subject
Re: [Casper] All of Caspers files?
infrastructure? If it?s new, I?d say back up any packages that you?ve
I?d be weary about feeling confident in the installation ? if it were me
anyway...
j
I just want to clarify a few points to make sure we're all on the same
page.
Issues are as follows;
  1. "Things are not replicating" I take that as packages, scripts
    etc... things that are normally located in your CasperShare folder on
    your distribution point are not syncing correctly upon their scheduled
    replication time. Are all of the Distribution points failing to
    replicate or just the ones you set up?
a. Are your servers each set up with your DNS to use FQDN? If so I
would delete them out of the JSS. JSS>Management>Distribution Points,
and re-add them with the FQDN if they were using IP prior, also make
sure that the "Casper Admin" and "Casper Imaging" user accounts
passwords listed for each distribution point match the local user
account passwords on each server Also make sure that permissions are
propagated down the CasperShare for each distribution point.
  1. "Adobe installs don't get listed in Casper Admin. " Does that
    mean they never do or some of them don't show up. Are you using JAMF
    method of creating the adobe installs via the Casper Admin application?
    Or are you using Composer and snapshotting?
  2. "Self Service is Super Flakey" is it not showing the packages
    that you have set up self service items for, or is it not laying the
    packages down correctly?
  3. "Re-Imaging is skipping the main Disk Image" What is it
    showing in the imaging log for a computer that has skipped the OS
    package? Is it failing on all or just the Distribution points that are
    not replicating?
  4. When you are talking about your techs not typing in the FQDN
    during imaging do you mean when the Casper Imaging app asks for the
    JSS's address? If so how are you imaging, are you using
    netboot/netinstall, recovery partitions, FW boot drives? The imaging
    techs should not need to repeatedly type in this information.
  5. If you "re-do" everything and change the DNS name of the master
    server you should just be able to make a new QuickAdd Package and push
    that out with ARD if you have it at your disposal to get the machines
    reporting in to the correct JSS address otherwise there are other ways
    to update the clients but I'd think that ARD would be the fastest.
Please correct me if I'm wrong on my interpretation and others on the
listserv please verify my advice. I tend to do some quirky stuff
sometimes.
Sorry forgot this J
-Dusty-
Dustin Dorey
Technology Support Cluster Specialist
Independant School District 196
Rosemount-Apple Valley-Eagan Public Schools
dustin.dorey at district196.org
651|423|7971
See below...
Rich Barron
