incorrect username/password is entered for this computer
  • June 3, 2015
  • 5 replies
  • 35 views
I'm running into this problem when trying to remote into a few of the users macbooks. It's not happening to everyone just a selected few.
Any help would be great
  • June 4, 2015
@EliasG Is it possible you have a different username? EX: Admin vs administrator.. Different build but short name? Have you tried using the CLI to SSH into the machine? using ssh "username"@10.5.3.221 ? ARD? you can also use whoami on machine.
Also i would run ssh -v "username"@IP to get a clear pic of whats going on..also on client look at log file.
Theres a bunch of reason why this would fail but lets start here.
  • June 4, 2015
@MAD0oM This is the username I use to remote into all users macs. It seems like its happening to a select few.
bentoms
Forum|alt.badge.img+35
  • June 4, 2015
@EliasG Is the same account the management account? Are policies &/or other Casper Remote commands working fine?
  • June 4, 2015
@bentoms yes policies are working fine.
  • October 15, 2015
We are seeing this quite often after our upgrade to 9.81. Still haven't figured out how to get around it.
