JAMF releases CS6 deployment doc...SOUP's DONE! :D:D:D
  • May 14, 2012
  • 20 replies
  • 103 views
donmontalvo
Forum|alt.badge.img+36
http://www.jamfsoftware.com/solutions/adobe-creative-suite/
http://www.jamfsoftware.com/libraries/pdf/white_papers/Administering-Adobe-Creative-Suite-6-with-the-Casper-Suite.pdf
Best answer by acdesigntech
unfortunately my company :(
But since now that I am 100% in charge of the entire Mac space across the globe... :D
Forum|alt.badge.img+21
  • May 14, 2012
Thanks for that :)
donmontalvo
  • May 14, 2012
FYI, page 9 includes an unfortunate limitation...
Important: Do not use the deployment instructions in this guide if the master distribution point in your JSS is an SMB share. Instead, use the deployment instructions in the following Knowledge Base article: http://jamfsoftware.com/kb/article.php?id=305
The meat & potatoes starts on page 11...Serializing Adobe CS6...
  • May 14, 2012
Page 4 of Adobe's AAMEE deployment guide 3.0:
The Application Manager does not support NFS or SMB.
  • May 15, 2012
Following http://www.jamfsoftware.com/libraries/pdf/white_papers/Administering-Adobe-Creative-Suite-6-with-the-Casper-Suite.pdf
Using an afp share
selecting "This package must be installed to the boot volume at imaging time checkbox and click OK." in Casper Admin
Adding to the config
imaging test machine with the config
Installation Fails!
  • May 15, 2012
only thing ive found that works it this and scoping for machine receipts of CS6 and a dummy receipt. Deploying through ARD etc doesn't work and so i can just push out a dummy receipt and recon the machine :)
https://jamfnation.jamfsoftware.com/article.html?id=161
  • May 25, 2012
Granted, I only had 1 user who needed it so far... but I was able to use AAMEE 3 to package a serialized copy of Adobe Illustrator, without having to take the next step of "serializing Adobe CS6".... Worked great... am I missing something?
  • May 31, 2012
Hi All,
Do you have to have Casper Suite for CS6 deployment or can I use this Casper Imaging as well?
In past, I have just uploaded the Adobe DMG file to JSS server and then Casper Admin to create new adobe installation which worked without any problem.
Would I be able use the same steps?
Thanks,
Raj
donmontalvo
  • June 1, 2012
If you're deploying at imging time, AAMEE 3.0 produced packages should work fine. I'm holding off until AAMEE 3.1 is released, since we lost a few features (can't include updates, not backward compatible with 5/5.5, etc.), 3.1 will reintroduce the features.
If you're "baking in" CS6 on a monolythic image, you'll need to install in Trial mode, and serialize after imaging the Mac. But who uses monolythic images anymore anyway...
Don
  • June 1, 2012
donmontalvo
  • June 2, 2012
@acdesigntech Congratulations, I'm sure you're gonna show them how it SHOULD be done! :D
  • July 18, 2012
I thought I had resolved my CS6 issues…
Seems to install OK if I reinstall Casper Client
– But when I try to install via a POLICY it errors out saying that it's trying to install at the root level "/"
Interesting that I DO get that with a Policy, but NOT with an Casper-Client install pull
- This seems to point to some bug in Casper ?
The LOG output specifically refers to "/" where as the AAMEE 3 setting was "Default Location"
I had the same result yesterday when I chose Custom an "/Applications" as the destination -- Policy Log said "/" as the destination & it failed…
Is Casper somehow mis-interperting the destination ?
So CS6 install via POLICY - does NOT seem to work…
Any Suggestions as how to resolve ?
  • July 18, 2012
I think its a Casper bug. I noticed a while back when on some of my machines weird folders and files related to extracted Pkgs were on the top level of the disk! You are not alone in this weirdness!
  • August 8, 2012
Is anything different with the instructions now that aamee 3.1 beta is out?
  • September 17, 2012
I am still having issues. I have repackaged with AAMEE 3.1 and still can't deploy during imaging.
  • October 10, 2012
Hey Guys,
In this document http://www.jamfsoftware.com/libraries/pdf/white_papers/Administering-Adobe-Creative-Suite-6-with-the-Casper-Suite.pdf on page 13 step 9 it says to add this command
/Library/Application Support/JAMF/Adobe/AdobeSerialization adobe_prtk --tool=VolumeSerialize --provfile=/private/tmp/prov.xml
Has anyone tried adding this line to the serialization package as a postscript? and did it work?
Kamal
  • January 3, 2013
Hey All--
I am having some minor trouble getting the package I've created with AAMEE to deploy correctly. I have followed the instructions, and read all of the tips and tweaks on this page, but to no avail. I am currently testing it as a Self-Service item, and when I attempt installation the logs show this:
/usr/sbin/jamf is version 8.62
Executing Policy CS6 Adobe Design and Web Premium...
[STEP 1 of 3]
Mounting afp://myshare/Casper to /Volumes/Casper 2...
[STEP 2 of 3]
Copying AdobeDesignWebPremium_CS6[AFP]...
Installing AdobeDesignWebPremium_CS6[AFP]...
Installation failed. The installer reported: dyld: DYLD_ environment variables being ignored because main executable (/System/Library/PrivateFrameworks/Install.framework/Resources/runner) is setuid or setgid
installer: Package name is AdobeDesignWebPremium
installer: Installing at base path /
installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Unmounting file server...
[STEP 3 of 3]
Running Recon...
Locating mobile device records...
Does anyone know if I am missing something easy? I wasn't able to fully understand exactly what this error was telling me. If anyone could shed some light that would be awesome :)
bentoms
Forum|alt.badge.img+35
  • January 3, 2013
  • January 3, 2013
Thanks for answering so quickly @bentoms unfortunately I am still receiving the same error, after caching.
[STEP 1 of 4]
Mounting afp://10.109.0.100/Casper to /Volumes/Casper 2...
[STEP 2 of 4]
Caching package...
[STEP 3 of 4]
Installing AdobeDesignWebPremium_CS6.pkg...
Any other ideas?
Thanks again for the link to this page for more resources.
donmontalvo
  • January 4, 2013
@rmaldonado I've seen this error when uploads via Casper Admin failed (corruption?). Have you tried re-uploading the AAMEE package again?
Installer: Installing at base path / installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Since this is an AAMEE installer issue, might also want to post at the AAMEE forum where the Adobe engineers monitor and respond fairly quickly:
http://forums.adobe.com/community/download_install_setup/creative_suite_enterprise_deployment
  • January 8, 2013
Thanks @donmontalvo, sorry for the late reply.
So basically it all boiled down to a corrupt package. We have an SMB share set as our master distribution point(hopefully changing this soon), and have that replicating to our 2 other AFP shares. To determine this, I just mapped to the AFP share manually, copy and pasted the CS6 pkg in there first, then copied it from there over to the master distribution share so that I could create a policy, and finally flipped the option within the policy to force it to always look to the AFP share. Ultimately this solution is working in the mean time until we can get our master distribution point changed to AFP. Thanks for the help and resources you provided for me to get this resolved for the immediate need!
