Problem Upgrading Adobe Update 9.5.2 manually Current Version is 9.4.0 (Mac OS X)
  • November 30, 2012
  • 8 replies
  • 87 views
I know i can go to the help and select check for Update and it will update reader with the latest version.
I am running with the Adobe Reader 9.4.0 on my Mac OS. I tried upgreading it to the Adobe Reader 9.5.2 (manually).
I have downloaded the update from ftp://ftp.adobe.com/pub/adobe/reader/mac/9.x/9.5.2/misc/AdbeRdrUpd952_ all_i386.app.zip
when i double click on the AdbeRdrUpd952_all_i386.app it ask for to choose the copy of Adobe Reader to update.
So i selected the location /Applications/Adobe Reader where my current Adobe Reader.app is (Adobe Reader 9.4.0) but farthe i am not able to select OK button.
Kindly guide me how i can update my adobe Reder with this 9.5.2 version.
But i am looking for a manual process is it possible?
Kindly guide me.
Best answer by tkimpton
Forget in app updating for Acrobat and Reader products.
Little tip for you... this has never ever worked properly for years.
Download all the updates and install them in order manually
Administration of the Acrobat & Reader products is a shambles
sooooo.......
  1. look at the Installation instructions for 9.5.1
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5354
This update requires that Adobe Reader 9.5 is installed on your system.
  1. and 9.5
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5334
This update requires that Adobe Reader 9.4.6 is installed on your system
  1. and 9.4.6
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5246
This update requires that Adobe Reader 9.4.5 is installed on your system
  1. and 9.4.5
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5115
This update can be applied to Adobe Reader version 9.4.4 only
  1. and 9.4.4
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5041
This update can be applied to Adobe Reader version 9.4.3 only
  1. and 9.4.3
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4978
This update can be applied to Adobe Reader version 9.4.2 only.
  1. and 9.4.2
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4935
This update can be applied to Adobe Reader version 9.4.1 only.
  1. and 9.4.1
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4897
This update can be applied to Adobe Reader version 9.4 only.
  • November 30, 2012
Advice Please....
Regards,
SonuW
Forum|alt.badge.img+21
  • December 1, 2012
Installation instructions must always be read, have another look.
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5436
  • December 1, 2012
Easily overlooked. Don't worry not you, it's Adobe being pants again with their installers. In my opinion Adobe Corporate need a massive kick up the arse to rid these stupid installers.
Adobe... Just to let you know, the modern world uses pkgs that admins can actually use!
  • December 3, 2012
@tkinpton
Thanks for advice..
For updating 9.5.2
as per url above it says.....
INSTALLATION INSTRUCTIONS
This update requires that Adobe Reader 9.5.1 is installed on your system.
I am confused here.. As i said i am running with the Adobe Reader base Version 9.4.0 and if i am looking for an update using Adobe Reader >> Help >> Check for Updates its shows me........that.... An Update for Adobe Reader to version 9.5.2 is available. Do you wants to install it now?
It means that if i will chose Yes it will update my current Adobe Reader 9.4.0 to Adobe Reader 9.5.2.
So same thing i tried to do manually by downloading the update from the given url....
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5436 it downloads the version Adobe Reader 9.5.2.(AdbeRdrUpd952_all_i386.dmg). double clicking the installer it ask to choose the copy of AdobeReader to update.
I have Adobe Reader 9.4.0 in Applications >> Adobe Reader 9 >> Adobe Reader.app
Logically it should choose this location only right?
Kindly Advice...
Regards,
SonuW
  • December 3, 2012
sooooo.......
  1. and 9.5
  1. and 9.4.6
  1. and 9.4.5
  1. and 9.4.4
  1. and 9.4.3
  1. and 9.4.2
  1. and 9.4.1
  • December 3, 2012
@ tkimpton,
Thanks for the solution. i have tested it it works fine now i have to update it in the incremental order as you advised me.
Thanks for the help.
Regards,
SonuW
donmontalvo
Forum|alt.badge.img+36
  • December 4, 2012
Wow...scroll down for the rediculous v9 update requirements...LOL...good thing X/XI updates are cumulative. :)
http://helpx.adobe.com/acrobat/kb/install-updates-reader-acrobat.html
  • December 4, 2012
@ donmontalvo Thanks for the kb article.
Regards,
SonuW
