Nothing I know of changed, but looks like we found a work around with this xml:
#for Python 3.4 - Need to run this command to install requests library to python: pip install requests
import requests
import warnings
import time
warnings.filterwarnings('ignore')
print ("PPS XML Mobile Exporter for Casper Start")
#Open URL
#Using the URL, UserName, Password, and turning off the certificate verification since the certificate is self signed
#always test url with browser first.
url = "https://casper:8443/JSSResource/mobiledevices"
r = requests.get(url, auth=('USERNAME', 'PASSWORD'),verify=False)
xml = r.content.decode(encoding='UTF-8')
#Open URL
#File
#Creates a connection to an output file and write out the XML data and close the file
file = open("mobile1.xml", 'w')
file.write(xml)
file.close()
#File
#Over Write File
#This needs to be done, so we have a new blank file, since the file is appended with every run through the loop
file = open("mobile2.xml", 'w')
xml = ""
file.write(xml)
file.close()
#Over Write File
#Mobile 2 - A more detail report loop, to get more detail on each mobile device, as a short cut I loop through more times then we
#have mobile devices, since I only write a line out if the data is xml, if the id is not valid, an html file is returned and is ignored.
for count in range(1,20000):
x = str(count)
url = "https://casper:8443/JSSResource/mobiledevices/id/" + x + "/subset/General%26Location%26Purchasing"
xml = xml + "
if xml[:5] == "<?xml":
file = open("mobile2.xml", 'a')
file.write(xml)
#time.sleep(10)
file.close()
#Mobile 2 - More detail report
print ("PPS XML Mobile Exporter for Casper Finished")
Gabe Shackney
Princeton Public Schools
