Ok I'm new to Casper and have not had much success so far. Much of this
was down to the new Leopard server installation, which I have now
resolved with a complete re install.
I had problems with the Adobe CS3 package, which I thought I'd resolved.
Last week it requested an Admin name and password, every time a User
launched Acrobat Pro. I recreated the Adobe installation, creating a
new .dmg file from the original disks, and dropping the dmg into Casper
Admin.
The only issue I had was that when a user launched any of the CS apps
for the first time, the request for a serial number popped up. Selecting
Quit, and re starting the app solved this.
I created a policy assigned to a test user, to update CS3 at login. So
just made ignoring the serial No request part of the re image/roll out
procedure.
This week, 3 Macs imaged all request the serial number and all now once
again request an Admin name and password every time a use try's to user
Acrobat Pro.
Nothing has been changed in Casper Admin, the Adobe installer has not
been touched. Believe me after I finally got it to work, I did not touch
it, there have been no additions or changes to it.
Any ideas
Phil Ryan
Oxford University Press
Oxford University Press (UK) Disclaimer
This message is confidential. You should not copy it or disclose its contents to anyone. You may use and apply the information for the intended purpose only. OUP does not accept legal responsibility for the contents of this message. Any views or opinions presented are those of the author only and not of OUP. If this email has come to you in error, please delete it, along with any attachments. Please note that OUP may intercept incoming and outgoing email communications.
