Is the procedure for adding a Guest VM Package still as stated in the 2009 white paper?
  • May 20, 2014
  • 41 views
Not seeing much on it, so I'm assuming it is but I want to make sure there isn't a better method first.
Best answer by TA373
You might want to check this out: http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2058680
Pretty 'inception-y' in that the deployment package is actually hidden inside the VMWare Fusion.app bundle - you have to pull it out, and then put the App bundle, as well as the VM's that you'd like to distribute along with the licensing configuration in there.
Great doc, worth a look.
  • Employee
  • May 20, 2014
  • May 21, 2014
Heh disregard this post, was a silly question.
  • Employee
  • May 21, 2014
Not at all- that Kbase article wasn't published until pretty recently.
The capability has been present for a while, but was only really well documented just a little while back.
